wayner's Avatar
Need pic of early (73>) p-brake clamp
Can someone shoot me a picture?
I have a 73 and am missing the peices that hold the parking brake cable to the rear suspension arms.
I've looked at the PET and am trying to figure out how many parts I need and how they install.
Could someone shoot me a picture of the rear of your emergency brake cable?
(The later suspension arms have a different cable fastening arrangement so I need 73 or earlier).
SOLD - 914 wide body hot rod
Old 08-06-2016, 04:40 PM
ahead of the curve
Jeff Burger's Avatar
for 73 rear arms part #51 is a hard plastic piece that attaches to the arms (with the associated hardware) and positions #49 , the metal tube around the cable just before it enters the rear brake assembly . I believe the cable also passes through 59 which is a fabric strap that attaches to the chassis. sorry no pictures
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 08-06-2016, 05:09 PM
wayner's Avatar
Thanks Jeff
That was a very helpful reference
(Returning a race car to the street and lots of bits missing with no idea that I even needed them )
Old 08-06-2016, 05:27 PM
Wayner,
I've had to do this before, not fun but not overly complicated either. Its called a parking brake guide, PN 901.424.562.01
I believe there is a bolt holding it on and the cable sits in it with a nut holding tension.
I don't think our host carries. Sierra Madre does but I recall getting from Stoddard. They are only about 5 bones
Little white piece above rear trailing arm:
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 08-06-2016, 06:06 PM
Success, found a better image online
1969 911E SOLD
2002 996 Cabrio
Old 08-06-2016, 06:24 PM
Send a message via Skype™ to Porboynz
I fixed mine into position with safety wire through a small drilled hole in the plastic bracket which is just a guide, the locknuts are for adjusting tension against the spacer tube.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-06-2016, 11:33 PM
wayner's Avatar
Perfect!
Thanks everyone!
I love it when a thread comes together
(Time to finally upgrade my black zap strap that I have been using)
Old 08-07-2016, 11:42 AM
Neilnaz's Avatar
Wayne, I have exactly the same kind of lash-up as you. The next time I place an order I will get a guide for both Left and Right Hand Side.
Good to see you back in the hunt - your threads are always good to read
Cheers, Neil
Old 08-07-2016, 06:01 PM
wayner's Avatar
Thanks Neil
There used to be so many of these how to threads, but not so much anymore.
I learned everything that I know here, but usually I didn't have to be the one asking the questions. I wonder if that is a sign of the collectors entering the market?
As for threads, I just started a fun one in off-topic
Old 08-08-2016, 07:20 AM
