964/993 rear seatbelts in G body?
Can 3 point rear seatbelts be retrofitted to an 86 911 coupe? I know the parcel shelf is different. Anything else? Will 86 factory install points work or does new threaded female recepticles need to be welded in place?
this may help, if your goal is simply to add rear 3 point belts (not go with 964/993 parts) 911rearshoulderseatbeltconversion2 - www
