door card plastic protection tacky adhesive
Which tacky adhesive can I purchase to attach the plastic sheet divider to the door panel. The plastic Im referring to the plastic that is between the door card and door panel (pictured)
I tried 3M weatherstripping glue which hardens ... I need something that will stay tacky And not dry hard. Is there a product for this specific job.
Old 06-23-2020, 06:38 AM
Pedro '84 Coupe's Avatar
I use this stuff. Stretch it out a little as you apply it to the door so it's not so thick.
https://www.napaonline.com/en/p/MST4195
2000 Boxster S and 2016 Audi A6
Old 06-23-2020, 06:51 AM
Designer King
Paulporsche's Avatar
That butylene tape can also usually be purchased at glass and mirror shops.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-23-2020, 07:52 AM
3M strip calk 08578
same as the Napa
Old 06-23-2020, 05:30 PM
SCadaddle's Avatar
Outdoor grade blue painters tape. Not nearly such a gooey mess next time you need access inside the door.
Old 06-23-2020, 08:47 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
I'm planning on using 3M Super 77 spray adhesive I have left over from my interior work. We'll see how that goes....
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 06-24-2020, 07:48 AM
Use the strip caulk. Trim adhesive is a flippin mess!! You can scrape the caulk off and clean off the residue with citrus cleaner. You get two to three “pull off plastic and reapply” episodes with the strip caulk. Also, i use heavy mil plastic from home depot and heat with a Heat gun or blow dryer to stretch it in cup shapes where need be. You can make deeper cups with the strip caulk to weld the plastic together. Did it all the time for car audio installs.
Old 06-25-2020, 10:26 AM
I have a friend with a picture framing shop and I used some 3M double sided adhesive tape I got from him. I have taken it off and replaced it twice and it still stuck. Looks like the stock stuff
Old 06-25-2020, 12:33 PM
Tags
door card , plastic , protector
