| jons911 |
09-09-2016 07:25 AM |
A little late to the party, but I figured I would summarize some points echoed in some of the responses here for others that come looking for 3.2SS advice.
- 3.0 SC came stock with 95mm p/c's with the cylinders having a groove on the top for a sealing ring, and the pistons had a 22mm wrist pin (US stock CR 0f 8.5:1, EUR stock CR 9.5:1 or 9.8:1 can't remember)
- 3.2 Carrera came stock with 95mm p/c's without the ring grove on the cylinder, and the pistons had a 23mm wrist pin (don't have a 3.2 so never learned what CR those ran)
- The bump in diameter to 98mm is usually complemented by twin plugging since the higher CR pistons usually start to block the flame path (pictures located earlier in thread), resulting in an inferior burn (although I have read of plenty of people running single plugs). It is also usually complemented with a higher octane rating fuel for further protection against detonation. 91/93 here in the US is usually enough for normal operations.
The 3.2 95mm cylinders are what you need if you want to bore out and replate for 98mm as the ring groove is too close to the cylinder wall on the 3.0 95mm cylinders. I picked up a fresh set of bored and plated Mahle cylinders for $1300 whereas to buy new Nickies from LN is $3700 ($4780 with JE pistons). Also, JE makes pistons designated for the SC vs 3.2 Carrera. Even though the pistons are the same size/design, they made them with different wrist pins to accommodate the two engines.
My build plan is a little less adventurous with 98mm p/c's, JE 10.5:1 CR, and twin plug. Depending on emissions, I may backdate the exhaust to SSI with M&K Sport 2/2 exhaust.
Hopefully someone will find this useful.
