Spumato's Avatar
Send a message via AIM to Spumato
Do short drives degrade engine performance?
All...
I am curious if frequent short trips can affect CIS performance.
Drives I am referring to would be less than 25 miles round trip, include spirited driving, but limit the engine temperature to sub 180 degrees in temp.
What are your feelings or reservations?
And if this does impact overall performance, what then is my remedy?
Ryan Russell
(405) 264-6288
Old 08-11-2016, 08:39 AM
DerkPerk's Avatar
I try to never short trip any of my vehicles. More to the fact of getting oil up to temp to burn off any moisture. No comment on CIS performance.
Sent from my XT1565 using Tapatalk
Old 08-11-2016, 08:45 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
I agree on having the motor warmed up during a drive. It is very hard on motors to only run them short distances where the oil does not get up to temp.
For many years I only had two cars. My 911 and a VW Beetle. For trips to the store and beach I drove the bug. To work, about 20 miles each way, I drove the 911.
That said, you should be able to get your car warmed up in 5 or so miles. (unless it's freezing weather)
It is said that 90 % of your engine wear occurs during warmup. I have been told you should not rev your motor when the oil is cold above 4000 rpm.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-11-2016, 08:59 AM
DerkPerk's Avatar
I believe the manual says stay below 3k until the temp gauge comes off the bottom.
Old 08-11-2016, 12:11 PM
billh1963's Avatar
Until your oil gets warm you won't boil off any water condensation that forms. Every weekend I take my cars on a 50 mile "test loop" to get everything heated up...plus, it's fun!
Old 08-11-2016, 12:47 PM
Tidybuoy's Avatar
Who wants to drive a 911 for a short trip? If your not having fun driving it, your not doing it right.
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 08-11-2016, 02:55 PM
T77911S's Avatar
its also bad for mufflers/exhaust.
condensation does not boil off and will rust them from the inside out.
true for any car
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 08-12-2016, 03:27 AM
SoCalSK8r's Avatar
Well short runs are better than not driving it at all. Don't sweat the details, you could die tomorrow ...just drive it when u want.
Old 08-12-2016, 09:37 AM
Reiver
Reiver's Avatar
Lol, he's right.
De Oppresso Liber
Strength and Honor 5th Legion
Old 08-12-2016, 11:29 AM
sugarwood's Avatar
I don't get the logic. You need to get to full temp to "burn off condensation"
Well, if you never start the car, you also will not burn off condensation either.
1986 3.2 915 911 coupe.
Old 08-12-2016, 12:00 PM
wayner's Avatar
Oil temp is an indicator of engine component temps.
Metal expands when it is hot.
Engines run loose until they are up to temp and parts are not running at optimum tolerance, therefore don't rev the snot out of them yet.
(But drive them)
Also, a heat differential causes the air to release its moisture. More heat will chase moisture away.
73 RSR replica
928 5 speed with phone dials and Pasha seats
914 wide body hot rod
Old 08-12-2016, 12:05 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
No.
The combustion process pulls water out of the air, as does the gradual heating of the oil and metallic engine components.
Old 08-12-2016, 12:08 PM
Drive it short. Drive it long. Drive it medium.
Drive maintain rinse and repeat
Old 08-12-2016, 12:10 PM
