Raising & Lowering Power Windows without a switch
Don't have the window switches installed in '83 Cab; what combination of wires need to be connected to raise and lower both windows
The red and brown wires are power and ground respectively. jumper wires from each one to the two remaining colored wires. Swap wires to go the other direction. The two other colored wires go to the two center terminals on the switch. The two red wires, one double and one single are both hot so use either one.
Thanks for the help John; i really appreciate it!
| All times are GMT -8. The time now is 03:43 AM. |
