Window tinter sliced my windshield gasket. Should I be concerned?
I'm a total 911 rookie here... So please with my dumb questions.
I had the front windshield tinted to cope with the florida heat. It's clear, but has UV protection. Anyway, they always trim the film on the outside of the car before putting it inside. It looks like he may have inadvertently trimmed a small chunk out of the bottom of my new windshield gasket. I noticed the piece was flopping a bit in the wind on my way home after having it done. It it just cosmetic to cover the outside edge of the glass or am I at risk for leaks now? It's a small chunk, maybe 5-6mm on the bottom passenger side of the gasket. |
I'd just glue it back down, should be fine. Tim
Unfortunately the piece is gone... It was hanging on by a thread when I knocked it off at the self serve car wash. Didn't bother to retrieve it.
Tint guy is going to replace the trim. As I guess he should. The trim piece is literally brand new. Any idea what the part number is? It's an 85 coupe. I went on Pelican and there are 9000 different versions of this wildly ranging in price. |
Make the tint weenie replace it.
He is...
I just need the part number. I'm overwhelmed by the number of options on Pelican. |
make them replace, leaking water = rust = problems you dont want or have now
Any idea what the part is?
Which car? '79 or '85?
do a search for 911-541-225-03 and add the specifics for your car They range in price from $28 (URO) to $141 for the superseded Porsche part.
The gasket holds the windshield in so the windshield has to come out to replace it. Is the gasket cut through? Do a search for windshield R and R because apparently not all gaskets are created equal. |
Not my car. A random white carerra pulled up where I was having lunch and took this pic. The yellow part is where he cut the chunk out.
[IMG]https://c6.staticflickr.com/9/8794/2...26a43e6e_c.jpg[url=https://flic.kr/p/L5Amtx][/IMG] |
So after seeing the pic, you're sure the glass has to come out?
Yes the glass has to come out.
The last thing I would do is replace the whole seal due to a small piece being sliced off - if the missing piece/chunk bothered me, I would simply fill and form it with black caulk (water based, since it is easier to shape and work with that RVT).
If it were my car I would have a new seal put in and have them foot the bill if they were willing.
Not a big deal to take the window out and replace that seal any good glass shop can do it in no time.
Be nice to see actual damage....if it's a mere sliver, personally can't see making a big deal about it. Tim
I'll see if I can get a pic... It's not huge. But I literally just put a new windshield in with brand new trim. So it bugs me :)
Trim and windshield are new, how old is the windshield gasket?
| All times are GMT -8. The time now is 07:01 AM. |
