-   -   911 to 996 front caliper adapter dimensions (http://forums.pelicanparts.com/porsche-911-technical-forum/925824-911-996-front-caliper-adapter-dimensions.html)
Madsimilius 08-17-2016 11:46 AM
Does anyone have a drawing or know the dimensions of the 911 to 996 front caliper adapters? SmileWavy
Trackrash 08-17-2016 01:15 PM
All the info you need is here. http://forums.pelicanparts.com/porsche-autocross-track-racing/921701-front-right-brake-wheel-locking-up-before-front-left-87-carrera.html
Madsimilius 08-17-2016 02:50 PM
hmm , don't know if you miss understood the question ? Couldn't find any of the info i need.
I just need the dimesions or a drawing of the front 911 to 996 caliper adapters.
Jaskas 08-17-2016 10:34 PM
Sorry, I cant help you with the right dimension. But I suppose you are using 996 discs as well. For 996 discs you need custom hubs. The dimensions of the caliber adapter depends on the hub dimension...
Madsimilius 08-18-2016 06:44 AM
I have the modified 944 hubs and 996 rotors. I can of course measure it but i think it would be a lot easier if someone here knew the dimensions.
