Holiday (short term) Projects
I know some of you guys actually pull your 911's off the street for the winter for some "real" projects.
I am off for the next two weeks, and am always looking for inspiration for some Pcar improvements (of course, after I complete the family induced home improvement projects). Tune up is already on the list, perhaps a short roadtrip up north to the Wheel Enhancement folks for some aluminum consultation and acquisition. What are some good short term projects you guys are working on?
85 Triple Black Cab <SOLD> 01 Triple Black Waterpumper |
Well I just bought my car a couple of weeks ago and a couple of little things are nagging me. Over the next two weeks I plan to...
1) Replace the bushings under the shift lever.(just did the coupler) 2) Replacing both horn grills and seals.(one is cracked) 3) Replacing the engine lid release T handle.(grabbing it w/ pliers just aint cool) 4) See if I can get the heat to work.
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
i finished all mine in nov/dec:
adjust valves change oil upgrade upper valve covers to turbo's reset timing, dwell bleed brakes track down and fix passenger side blinker problem get 1 more run at the streets of willow i can get drunk every day from christmas until new years. |
It'll be legen-waitforit
Ah yes winter projects.....I am suppose to be building the basement, but I've been "tinkering" with my 911.
Took apart/off the alternator (Beeatch to get out) refurbishing it. While out, polish fan, powder coat, clean fan housing, powder coat. Replace spark plug cables (shiny new red ones, present to myself) Change plugs, dist cap, rotor. Paint headlight interior plastic ring body color. Clean engine look for leaks and drink beer. Cheers
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Can't get too deep in a week and a half, but I do plan to
1) install the hardware for the 5 point harness, 2) Install the new BK Fire Extinguisher mount 3) If it turns out santa can take a hint, I'll be installing a fender mounted oil cooler 4)Fixing my windshield wipers
Jeff C 76 912E 2.6L |
Bandwidth AbUser
During the holidays I'm working on the 73E. My projects are
- Shifter and shift coupler bushings - Front hood shocks - Interior color change (already started) - Get H4 trim rings chromed and install H4's That's a lot on my to do list. We'll see how much I actually get done. I'll also try to get out for a drive in the countryside every now and then, as weather permits.
Jim R. |
Senior Member
Re: Holiday (short term) Projects
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
oil change and replace tail light lens seals. The in-laws get in town Sunday, so I suspect I might have to...ummm....fix some other stuff...and then test drive it. Yeah, that's it. Test drive. Just a few hundred miles.
Hilbilly Deluxe
Pull the engine and tear it down.
See what I find, and start planning from there. Tom |
B58/732
Headlight lens replacement............CHECK
Seatbelt replacement ....................CHECK Foglight repair................................CHECK Targa top recover (JMPRO?) Targa Top seals A-pillar/vent window seals Fix driver's door rattle (window?) Clean/Lube window mechanisms...CHECK Locate and fix oil leak(s) New airbox lid strap.......................CHECK Fix A/C blower Replace heater hose......................CHECK Replace Targa bar rear window seal....CHECK Rebuild pedal cluster New brake pads New rotors (if necessary) Brake flush Get windshield washer(s) working. Change transmission oil Big time detailing Unfortunately I did all the easy stuff (aka "low hanging fruit") and am now sidetracked trying to get my Honda running. If there's one thing that's under my skin more than Porsches, it's motorcycles...and having sold my regular scoot months ago, I'm starting to get itchy. MUST.......RIDE.............
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Holiday projects
My projects were to get my new ducktail on and start getting car ready for a complete paint job, flush brakes and remove old valance and install new valance with spoiler. OT- Just got bad news a few days ago and I'm up here in Sacramento area for my my Dads opperation, all went well with the opperation and they removed a section of his colon as he had a milignant tumor. Nice to be up hear with family and to still visit this site and keep a positive attitude with life in general " live each day as your last".
I'll be home for Xmas and back to my family and working on the P-car, wish you all good health and have a happy and safe holidays. Cheers, Rick
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
This exercise will help me get organized - thanks
On the 911S Lower rear - corner balance - alignment Install hood rally lamps Relays for headlights and driving lamps Weber rejetting and adjustments R&R - Recalibrate speedometer for new 50 series tires Get the d$$% tachometer to work with the MSD ignition Get the oil tank sender to work Minor adjustment to shift linkage Repair cracked rear fiberglass bumper and install On the Carrera Change to SWEPCO Install sports trans/motor mounts Install new Koni shocks Troubleshoot erratic miss and surge Install new steering shaft bushing Gosh - I better get working!
Joe Riley 84 Carrera Targa 69 911S Coupe Click here for 911S project "updating as I go" |
OK, Now I am getting motivated--building a list. But here is one that I have yet to see on the board:
Windshield. Mine is the original. It has dings, scratches, swirls (real obvious when driving west into the lovely California sun). Is there any way to get rid of this stuff so it will somewhat resemble a clear piece of glass?
Man, some of you guys are going for it!
Me, rebuiding the front end. New bushings, ball joints, tie rods and so on...
Doug '67 911 2.2 |
B58/732
Mine looks like it's been through a sandstorm (which it has). With all the pebble/gravel "landscaping" around here, eventually I'll get a crack in it; then my insurance will pay to have it replaced with OEM glass. Until then, I'm going to have to squint. Someone mentioned some time ago to try polishing with fresh newsprint. Haven't tried it, but can't see how it could hurt. Just realized that my project list is missing: Find and eliminate vac leaks (or, replace all vac lines!) Replace struts Alignment Sigh. At least I got the Honda 3/4 running today! (yes, running on 3 cylinders....time to tear down the #2 carb....again.....)
I'm planning on a little road trip (3000-3500 miles) (thanx Ron) middle of Jan so I recently did oil/filter/air cleaner, changed plugs/wires(magnacor) rotor/cap, valves, bled brakes, rotors and pads fine though I had planned to change them. Put on new speaker grills and a 930s wheel. Siliconed the gold creast on the wheel (looks great). Will lube the normal stuff, doors cables etc. shortly. Am now installing a CB/antenna for trip insurance. Hopefully I will be installing a V1 next week (If SC shows up as planned). Also putting together a trip kit (spares/tools).
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
My list will keep me busy this winter. Some I've completed already and others are waiting to start.
1- replace old leaky fuel lines to fuel pump. 2- replace trombone oil cooler with Carrera type. 3- replace permatune with MSD along with coil 4- replace front bushings with Chuck's bronze bushings 5- install relays for H4's and starter 6- replace cam oil line fittings 7- install new motor and tranny mounts Other than that it will be a quiet winter.
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
Stone,
Bluesky, Try Bonami scouring cleanser, you can find it at most grocerey stores. I did my windshield that had wiper scratches, road blasting and it came out 100% better than it was. my .02 Rick
All Winter project !
Soory no time for talking...
i have to work on !!!
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! |
Bandwidth AbUser
- Shifter and shift coupler bushings replaced. Adjustment of shift coupler not tested due to dead batteries and now, uncooperative weather. - Front hood shocks replaced - Interior color changed to black. I still need to replace the brown carpeting with charcoal carpeting. I'm indecisive about the type of carpet to put in but hopefully I'll get over that shortly. - One of the local (NoVA) Pelicanheads is buying H4's with chrome trim rings and we'll trade trim rings. He wants to have trim rings painted to match his body color. - Unplanned removal of crappy old batteries. I'll clean up the battery boxes and try to buy one of those dry cell batteries (e.g. Stinger SP800) - Replaced gas cap and filler flap. - Rewired stereo so it uses PO-installed Blaupunkt front speakers. PO only had stereo connected to the dash-top speaker...yuk! I wish I had more time as I was really having fun with these projects.
Jim R. |
