1980 sc won't start?
I purchased a 1980 sc with 75k miles. Great car but won't start. I've sprayed it with starter fluid but it makes no attempt to turn over.
What should I be looking for? Thanks guys
Old 08-21-2016, 05:58 AM
Fahren mit dem Wind.
mhackney's Avatar
More information is needed, please be detailed. Like where did you spray starter fluid. Where are you located? (weather/temp can have an impact plus there may be a Pelican in the area that might be able to help.) How long have you had the car and did this problem just appear? The more detail, the better.
"no attempt to turn over" - does this mean that the starter motor is not even engaging to turn over the motor or that the motor is turning over but not firing?
In any case, the diagnostics are check for spark and fuel first. If those check out, we move on to "air".
1) are you getting spark? Do you know how to test this?
2) are you getting fuel? Do you have a fuel pressure gauge (an absolute must have for SC owners IMO) and have you tested the fuel system?
3) air is a little tricker for CIS systems but if we need to go there, you'll find plenty of help here.
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 08-21-2016, 06:30 AM
Does it start if you bump it in gear?
1983 RHD SC 3.0
1994 RHD E31 850 CSi
RETIRED
Joe Bob's Avatar
CIS is all about fuel pressure, then spark and air. Check for spark....does the CDI box whine when the key is turned? Did you have a back fire last time it ran?
Gauges are a good tool to have for diagnosis on start up pressure. Does the fuel pump run when key is on and the flapper in the air box is lifted?
2012 ML350 3.0 Turbo Diesel
Old 08-21-2016, 06:47 AM
Thanks guys. I live in northern NJ. I haven't dug too deep into yet. The car didn't start when I bought it a few months ago. I haven't checked any of those things yet but will try this week. I've got a few other (6) cars in my garage and wanted to find a mechanic who is willing to work part time on 911s (73.5-81) if there's anyone out there.
Old 08-21-2016, 07:03 AM
CIS troubleshooting........
Painthouse,
I will be back home next week. PM me your address and telephone number. Need to drive my cars out after being away for almost a full month. I will take a quick look at your engine and give you some tips to get it running. Keep us posted.
Tony
Old 08-21-2016, 08:19 AM
83 911 Production Cab #10
JJ 911SC's Avatar
... I've sprayed it with starter fluid but it makes no attempt to turn over...
No sparks
Who Will Live... Will See
Old 08-21-2016, 09:51 AM
Cranking the engine........
Were you able to crank the engine with the starter? The engine won't start if you were unable to crank the engine. So what did you mean 'no attempt to turn over'? Engine cranking but won't run? Be more specific. Thanks.
Tony
Old 08-21-2016, 03:28 PM
Paintboss,
Tony (boyt911sc) is the best. Super knowledgeable.
"Life is good"
Old 08-21-2016, 04:12 PM
Just an avid CIS troubleshooter........
Originally Posted by Richard C2S View Post
Paintboss,
CORRECTION:
I am not the best nor super knowledgeable, just another DIYer that enjoys CIS troubleshooting. Thanks for the compliment. The more difficult the problem, the more I like to get involved and I am still looking for a CIS problem that a typical DIYer like you or me could not diagnosed correctly. The difference is that I spent a lot of time researching and testing CIS components to learn and understand how they operate. Reading technical bulletins and manuals are not enough. There is no substitute for hands-on experience.
Tony
Old 08-21-2016, 07:07 PM
