-   -   3.6 conversion Brain ;part three (http://forums.pelicanparts.com/porsche-911-technical-forum/92627-3-6-conversion-brain-part-three.html)
Kevin Stewart 12-31-2002 06:01 PM
The BRAIN, Slammed will like this part as he waits for these parts to arrive at his door, I havent got my install kit from Timmins yet so I decide to start doing some things that have to be done, I have the new brain and decided its time to take the old one out, please remember that at this time you have the battery cable off, i have power seats, so to take out the seat i had to move it forwrd, reconnect cable hit key woops, fuel all over the floor, so please pull your relays, The first thing i noticed was that i keep the car clean but, things have found thier way under the seat, anyway, pull the clip holding the connection to the unit and pull the wiring connection from it. There are three 8 or 9mm bolts holding it down to the floor. when you lift it you will see a ground also undo this bolts it has two brown wires and is held in place by a 10mm bolt, the brain is removed and the wiring is loose. The wiring loom runs along the center tunnel back to just above where you disconnected the shifter, pull (see picture) there is a rubber groumet here that goes in a hole about a inch and a half, the 3.6 loom has a groumet thats (i havent measured yet) like 2.5 inches round, Im gonna buy a hole saw the correct size so the groumet will fit neatly. You will notice that I havent removed the cdi and tray (see picture), I have decided to wait on the kit instructions to have a better ideal of where to cut the loom. I want to have enough wire to be able to do my wiring, but also leave slammed enough to do his, there is a new brain and wiring to the engine that will be installed. Like I said I will wait on the kit so that I can see what they suggest and make my decisions from there. As always any questions let me know, stew09@aol.com , Kevinhttp://forums.pelicanparts.com/uploads/DCP_0034 new.jpg http://forums.pelicanparts.com/uploads/DCP_0039 new.jpg http://forums.pelicanparts.com/uploads/DCP_0041 new.jpg
rattlsnak 12-31-2002 06:27 PM
You'd better get a better wiring diagram, your pointing to the rear window defogger relay, not the CDI box in the last pic..
J/K ;)
Kevin Stewart 12-31-2002 06:39 PM
1 Attachment(s)
Actualy you are right but i did list it as cdi and tray (see picture), the cdi box sits on the same plate as the the relays and it all will be removed. so ill add anouther picture for you, I hope this is better, Kevin
Kevin Stewart 12-31-2002 06:44 PM
I do have a new style box that will go there, Kevin
rattlsnak 12-31-2002 07:00 PM
I hope you realize I was just picking at you,.. !
dean 12-31-2002 07:02 PM
How do you do the nice captions on the pics?
Kevin Stewart 12-31-2002 07:19 PM
rattle its cool im just trying to do a good job so others dont get lost,
Blown do you have any type of photo shop, i have a cheep paper port scanner, after scanning the picture click to enlarge, and on the left you will see pencils and stuff just play with it, im pretty sure most are the same just go to edit picture, i also have to shrink the picture with my photo suit software, my new lap top is supposed to do it all with the windows xp version I have, but cant tell you a thing had it a month and used it twice, the soft ware on this computer is over a year old so that makes it antique, e-mail me if you think I can help, by the way I usualy have to ask my 16 year old daughter when im lost, stew09@aol.com Kevin
Mifintifin 12-31-2002 07:22 PM
Um, quickly as I have a party to go to!
Do not remove the isolated relay shelf. You may still need the relays & fuses and the 14 pin connector in the rear connects to the 964 and/or 993 engine interface connector (with adapter or with pins moved). Remove the CDI unit and all the wiring to it as well as the entire old DME harness. Don't cut any harnesses! There is no reason to. If you are installing a 964, the coils and coil actuators mount where the CDI was mounted. The harness hole needs to be opened up to 2.25". DO NOT USE A HOLE SAW! The main battery cable loom is hidden behind your torsen tube exactly where you will be cutting. Use a nibbler from the inside of the car. If you don't have a power nibbler just use a hand model, and as a benefit, it will give you Popeye forearms.
Cheers,
Mifintifin
Kevin Stewart 12-31-2002 07:28 PM
Mifintifin yes I am aware of the harness, but i will be cutting the hole from inside the engine compartment to the cabin of the car, i see what you are saying, but there is no risk because inside the cabin there is nothing to damage, most of the parts will fit in the new box i am installing right where that plate is, Kevin
dean 12-31-2002 07:57 PM
Kevin, No photo shop and no daughter. Geeze those kids are wizes with the new fangled stuff.
Kevin Stewart 12-31-2002 08:01 PM
Blown, do you have a scanner or a digital camera program sometimes they have them, I bought my scanner for like 50 bucks, my photo suit program cost like 49.95 at best buy either will work, or send them to me and ill do it for you, Kevin
ischmitz 12-31-2002 08:03 PM
Kevin,
I just measured the stock rubber boot on the DME. In my case I have to cut a 60mm diameter hole into the firewall.
For what it's worth you can check out my web page. Its www.di.com/home/ingo
Go to Targa, Conversion, Electrical. Just finished throwing some pictures in there tonight.
Happy New Year,
Ingo
Kevin Stewart 12-31-2002 08:11 PM
ischmitz im sure the hole i need to cut will be the same, feel free to add anything you have found as you go on my post, I actually have my car on four rail road ties that are about 18 iches long with stops on it, I can get under the car and the motor slid right out with out having to jack the car up, but remember to start cutting from the engine compartment side or like the other post said you will get the harness, Kevin
ischmitz 12-31-2002 08:18 PM
I have yet to fix my tranny before the real work can start. Maybe I'll start on the harness installation in the meantime. I yet have to figure WHERE exactly to cut the hole.
Have you seen those neat hole cutters where you drill a pilot hole than put one half of the tool to each side of the culprit and tighten a screw to perform the cut. Not sure what they are called. A friend borrowed me one for the oil cooler installation. It makes nice round holes and ate the 2mm sheetmetal like butter.
Do you have a web site or something where you share what you are doing?
Ingo
Kevin Stewart 12-31-2002 08:25 PM
ischmitz, no web site, i have been so busy that its all i can do to post here work and do the conversion, its called a hole saw, they are like 5-8 bucks at Lowes or Menards and come in 60mm size, I am gonna use the hole the old harness came out off, i just have to enlarge it, look at my picture and you will see the hole it has white around it, have you taken your old harness out yet? anyway it is right above the center tunnel, when you took the plate off to disconnect the tranny from the shifter, its about two inches above that, what year is your car, if you have a brain under the passenger seat then you will already have a hole and just need to enlarge it, and I promise a web site as soon as this conversion is done, Kevin
ischmitz 12-31-2002 08:43 PM
Mine is a 74 with no brain. So no hole. I thought the hole for the DME harness would be cut into the firewall to the left of the drivers side shock tower top inside the engine compartment to protect the harness from the elements.
By putting the hole close to the tunnel the harness would be pretty exposed wouldn't it?
Ingo
Kevin Stewart 12-31-2002 08:55 PM
If you look at the second picture down you will notice the hole I am talking about, you will also see the control arms, it comes out of the hole and immediatly turns left torwards the drivers side of the car,yea no more exposed then anything else, Kevin
ischmitz 12-31-2002 09:32 PM
1 Attachment(s)
Kevin, I wish someone would chime in here. From the attached picture and where the boot sits on the 964 DME harness the only sensible location for the hole would be where the red arrow points.
The dull part lying across the rear cross member is the sticky cloth tape insulating the harness. That is supposed to run inside the passenger cabin from what I understand. It sort of glues the harness into place.
If I would choose your location I would either have to relocate the rubber boot substantially or the entire cabling would not match to the O2 sensor, the coils etc.
Kevin Stewart 12-31-2002 10:19 PM
ischmitz , i went out and looked you are right it appears it should come out the center, i hope to get my kit next week and we will know, if not we will have to post, or i may just hook the loom to the motor and see, Kevin
Speedster94 01-01-2003 11:03 AM
wiringharness
hallo Ingo and Kevin
That is the exact Point to go trough the Body , you will have all the Wire above the Engine and keep it away from the weather .
On the Inside you just follow the Wheelarch and then below the Rocker to the middle of the seatconsole ,you go trough the Console and you are there . If you guys need Pictures from a C2
Enginebay and rearseat area let me know . I am to stupid to post them here .
happy new Year to all : harald
Kevin Stewart 01-01-2003 11:35 AM
Harald it would be great if you had time to post a picture, Thanks in advance, Kevin
Mifintifin 01-01-2003 12:51 PM
Kevin & ischmitz
Wow, what a party...anyway, I logged back on and saw some more postings. Here's mine
On an SC that already has a DME hole as well as the brackets for the DME under the Passenger seat its much easier to use the same hole. Just slide the grommet down the harness and route the harness the the same as the SC harness. Before mounting tape up the entire fabric portion of the harness that will be exposed under the car with good quality Vinyl tape. It is also a good idea to get the various bends and curves in the harness before you tape it, it will be easier to mount.
On the earlier car that had no DME its up to you. However, routing the harness in the C2 position requires a lot more dismantling of the interior IMHO. I route them all in the lower position.
Kevin, a hole saw will not work for enlarging the old DME hole. First, there is no metal in the center for the pilot drill to go through so the saw won't stay centered. Second, there isn't enough room from the outside to get the hole saw in the proper position to exactly staddle the vertical wall that the old hole is in. You will end up cutting it up to high which will be in the bent portion of the wall. The grommet will then have a bend in it which won't seal right. Again, I recommend you use the nibbler. The hole saw is OK for the C2 position. 60 mm is OK but I like the tighter 2.25"
Cheers,
Mifintifin
911nut 01-01-2003 02:44 PM
Add me to the others who say NOT to use the hole saw for enlarging an existing hole. Hole saws come with a place to attach a drill bit at their center. The drill bit penetrates the material first and anchors the saw into position.
With nowhere for the drill bit to go the torque generated by the drill motor will make the hole saw walk all over the place and it won't cut.
Use a Dremel with a 60 grit sanding drum (you'll go thru a whole pack but they're cheap).
Embs 01-01-2003 03:40 PM
1 Attachment(s)
Kevin,
They make panel punches (not sure if that is the most accurate term) the male piece slides into the female cutting the metal. You use a wrench on each side to pop the larger hole in. They work great and you can rent them.
Electricians use them on large electrical panels to pop new holes in for conduit.
They look like this:
Kevin Stewart 01-01-2003 03:52 PM
Todd, as Mifintifin said its a nibbler we use these on the aluminum on the race car, a nibbler works fine in odd places but left or right side cuts would be better, the niggler is more for a square cut, I really think when it is all said and done, the next few people that do a 3.6 will have it easy, but, im looking at c2 prices and thinking, hmmmm, they are getting low, Kevin
Early_S_Man 01-01-2003 03:55 PM
The hole-cutting devices Ingo was referring to are called Hole Punches mfr'd by the Greenlee Tool Co. ... been around for more than 50 year in the electronics industry for use by DIY-type hobbyists and prototyping at small labs and shops. Allied Elecronics has always sold them, as did many Radio-TV shops back in the '60s.
http://www.alliedelec.com/catalog/pf.asp?FN=1016.pdf
Kevin Stewart 01-01-2003 03:59 PM
Sorry didnt see picture, nibblers look like pliers or metal snips but just nibble at the metal, if remember itcuts a 1/8 by a 1/4 piecs each time or smaller, Kevin
ischmitz 01-01-2003 04:41 PM
The tool in EMB's picture is exactly what I was using for the holes in my 2mm custom made box for the oil cooler.
It cuts perfect holes. That's the way to go.
Ingo
47silver 01-01-2003 04:43 PM
hole punch
kevin
greenlee makes a hole punch that you can use to make a perfect hole. we use them at work, i dont know what they cost off hand, but we use them to make holes in control cabinets and other sheet metal.. you drill a 3/8 pilot hole and use a 7/8 ratchet or wrench to tighten the punch into the die.
if you cant find them ill check my sizes at the office if you want.
gary
Kevin Stewart 01-01-2003 04:57 PM
Hi gary , guess where we are at is there is aready an existing hole on my car, do i enlarge it or move the hole to where a c2 would be in that case i would need to make a new bigger hole and fill the old hole, really this isnt brain surgery and both locations will work fine, the problem is the location of the c2 harness's groumet is in a different place then the sc, so if i use the sc hole i have to move the groumet and tape up or shrink wrap a section of the harness, 5 nickles or i quarter or two dimes and a nickle, i guess the question is which door do i wanna use, Kevin
dean 01-01-2003 05:40 PM
You can use a hole saw to enlarge an exsiting hole. All you have to do is weld a piece of metal across the hole for the drill bit.
