one of gods prototypes
question on dropping my exhaust....
the exhaust manifold nuts/studs are pretty rusted where they mount to the heads and i want to drop my exhaust, if these strip out/break what am i going to need to do to replace the studs?
i want to have everything onhand before i go at it. thanks in advance guys...........and happy new year
Brought to you by Carl's Jr. |
I think the trick here is not to break any,easier said then done.I replaced the exhaust on a 1974-911S that I owned a couple of years ago and everything was rusted,I sprayed each of the nuts 2 times a day for a week with PB Blaster,then I started removing them slowly,tapping them with a hammer to loosen them up,this worked for about half of them,the other half I heated with my oxy/acetelyne torch and they all came off without breaking.I then cleaned each one up with a wire brush and coated each stud with anti-seize compound,works like a champ.If you break them off,depending where they break,you may have to drill them out,heat them and grab with vise-grips etc.Good luck.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
RETIRED
Try not to break them in the first place......lot's of penetrating oil....NOT WD-40, use Kryoil or Liquid Wrench....let is soak, then turn a bit, tighten and soak again.....
If they do not break loose you will need some heat. Do a search, there are many threads on the subject. Do not let them break, they will be a real pain. Once you get the heat exchangers off, you can double nut them and replace them. |
I fully agree with both replies. When I put my headers on, I sprayed a penetrating fluid onto the studs for about a week before hand and undid themvery gently - not one broke!
Steve in South Africa If it isn't sideways, it isn't fun |
I would also clean up the threads on the exposed studs after the removal of the h.e., before the reinstall (it's a metric pitch, of course, so if you don't have the proper die, be careful at the hardware store to make sure you've got the right one!)
Good luck
Remember our friends: Warren, Ron, Grady, and Steve. 76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster |
thanks for the help guys.........so i guess i don't want to break any studs LOL
first application of penetrating oil went on an hour ago i can't wait to get my torpedo heater back from my father.........
Use oxygen/acetylene torches and heat the nuts until they are cherry red, then remove them while they are still glowing. That is the best insurance against breaking a stud.
John Adams 1980 ROW 911SC |
