Do I need to strip my engine tins?
So, i removed my 4 perimeter engine tins (not the fan shroud) as part of my reseal and decided to freshen them up a bit. So I sanded down the trouble spots with a wire disk and then painted the tins with a coat of Rustoleum Rust Reformer rattle can paint and then a couple coats of Ultra High Temp black rattle can paint.
Then I realized the Rust Reformer is not high temp paint and in fact says not to apply to surfaces that will exceed 200 degrees when heated. Am I screwed?
Andrew 1987 Carrera Cabriolet 1988 Carrera Coupe (RIP) Gone are the days we stopped to decide where we should go......we just ride. |
I wouldn't worry about it.
Thanks for the quick reply, JWW! Pretty psyched to have the engine close to going back in and car running after almost two years and this had the possibility to be a real setback and disappointment.
I powder coated all of mine in factory color, should last a long time and clean up easily
I blasted mine and then primed and painted. I don't think I user a hi-temp paint either, and five years later they are still fine. The only think that may happen is some dimpling in the paint, but since it is black, you barely see it.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Registered Minimalist
Powdercoat. Looks amazing, cleans easy, durable and not that expensive.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I powdercoated mine too.
it does not cost that much, got a great relationship with my powercoating guy. I felt like he did not charge enough for the work he has done in the past so I paid him extra. now I take small stuff to him and he does not charge me
86 930 94kmiles [_ _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ _] RUNNING: [__] NOT RUNNING:01 suburban 330K:: [_ _] RUNNING: [__] NOT RUNNING:RACE CAR:: sold Last edited by T77911S; 08-24-2016 at 06:51 AM.. |
