72 hand throttle and e-brake?
About 2 months ago the plastic piece that grabs on to the throttle rod broke. So I took e-brake assemble apart. I have new piece and I'm about to install. Do I just put it in place where old is and then just jimmy it over the throttle cable? Or is there more involved. Also the e-brake has a double sided hook. One side hooks into the cable which controls the function of the e-brakes in the rear. The hook pointing towards the front does what or hooks into where?
72 911 Although it is done at the moment, it will never be finished. |
Author of "101 Projects"
You can swap this without taking the e-brake apart - just did this on Scott's car a month or two ago.
The plastic piece requires some maneuvering, but it will fit in there. It's not a throttle cable, but a rod... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks wayne. I took it apart a while ago and kind of forgot how it goes back together. Does anyone know why the e-brake has a double sided hook? Like I said in the above post, the hook pointing toward the rear of the car "hooks" in to the cable and pulls on the ebarkes. But why is there a hook pointing toward the front. Does this serve any purpose?
What a frickn hassle that was. But taking the whole unit out, cleaning it up has made the e-brake, the heater and the hand throttle so much smoother now. While I had it apart there was a half way dissolved rubber boot wrapped around the shifter and throttle rod. I'm amazed that when it was all back together how much smoother the whole apparatus is now.
Still not sure why Porsche created the double sided hook. Oh well. This was also the first time I drove this car in 2.5 months. You forget how fun it is to drive these old cars. I can’t believe how well my car “turns in” to a corner. And it’s cool that such an old car can handle pretty damn well compared to all the new stuff out there.
This is old, and I'm a dork. That double sided "hook", well that's what tensions the e brake (for both sides). In other words, only one was attached and it was attached on the wrong side for some reason. I guess I thought those cables connected into one cable (in the tunnel) and then attached to the e-brake handle at one spot, uhhhh no. DUH! I went to adjust the pass side e-brake and well it would not adjust properly. Took e-brake out, (somewhat) and noticed that the drivers side cable was crossed over and was attached to the passenger side hook. The other cable was hidden under the shift rod. What a frickn mess and hassle that was to fix, i'm guessing it has been like this for over 20 years now. All fixed.
What's cool about this old thread is that back in the day Wayne had time to help users out.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 08-25-2016 at 02:13 PM.. |
I took my seats out to do this. Made it a lot easier but it's still fiddly.
Steve B. 1972 911t 1999 328is |
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
Just a heads up in regards to the white plastic hand throttle linkage. There was no c clip holding it on, and really it isn't needed. The placement of the e brake, etc. forces that white plastic piece up against rod and there really is no way that it can come off. So if you lose the c clip, which I think I must have, don't worry about it.
83 911 Production Cab #10
Long shot but where did you get the plastic piece?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Many places carry the white plastic piece and Pelican is one of them.
I thought it was the famous NLA.
Got it..., 901-424-317-00-M100 1972 Porsche 911 S Coupe/Targa - Fuel System - Page 4
