rs911t's Avatar
Novice oil drainage question
Drained my oil for the first time, per the instructions in '101 Projects'. Wayne notes that the sump contains significantly less oil than the tank. Well, it was just the opposite for me. Very little from the tank, most from the engine. It was cold and has sat for a couple weeks. Any significance??
Greg
Old 01-03-2003, 07:17 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
My car was the same way when I drained it.. I think since you're supposed to have the oil warm when you change the oil it will normally be mostly in the tank and not the sump and it seeps into the sump slowly after you turn the car off.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 01-03-2003, 07:19 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I have always run the engine up to temp first and the majority of the oil comes from the tank.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 01-03-2003, 07:29 AM
bigchillcar's Avatar
Yeah, you do it with warm oil because it will flow out better for a more thorough change.
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 01-03-2003, 09:11 AM
And because by running the car, you get all the particles and sludge circulating, so that it comes out with the oil. By doing it cold, you let all that stuff stay on the bottom of the tanks, to be mixed in with the new oil.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 01-03-2003, 09:27 AM
rfuerst911sc's Avatar
I agree,you should do it with the oil warm,it helps keep the junk that has accumulated in suspension in the oil and you have a better chance of getting it out.
Old 01-03-2003, 09:39 AM
rs911t's Avatar
Thanks for the info. I agree - better to do it warm. Fortunately, the oil was changed about 1300 miles ago by the PO. This drain was for valve adjustments. Just so happen it's the first time for me.
Greg
Old 01-03-2003, 09:57 AM
pwd72s's Avatar
Greg, oil should be warm when drained, valves should be cold when set...a rub, since most DIY guys want to do both at the same time. One trick is to drain in the evening, let the oil drip into pans all night, set the valves the next day. Not easy if the car is a daily driver, I'll admit. The infrequent cold oil chnge is better than no change at all...
Old 01-03-2003, 10:20 AM
