dash pad interchange
Anybody able to answer this one?
Will the dash pad of an '86-up with the long, one piece defrost vent fit earlier models...say a '79?
Old 01-02-2003, 07:35 PM
Yep, but you have to make changes to the windshield vents near the glass. The holes where changed in the dash, you have to cut.....
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT -
09 Audi A4 Avant - daily driver
Old 01-02-2003, 07:48 PM
Kevin Stewart's Avatar
Hi yes you can put it in with out cutting, i put a 94 dash in my sc, most of the bolts line up, but when it came to the vent on the windshiend i used black sheet metal screws, if you had to you probably could do it with out removing the windshield, the leading edge of the dash near the windshield doesnt mount like the sc so it makes it possible, at first i was gonna cut the defrost vents then i just tried it with out the cut worked just fine or should i say as good as it used to, they are not perfectly lined up but good enough, Kevin
Old 01-02-2003, 08:04 PM
Todd Simpson's Avatar
I tried to put an '86 dash in my '83SC. I remember it being more work than it was worth, the defrost vents were too different. I bought the used '86 dash for $250 and sold it for the same. A new SC vinyl dash (a few years ago) was around $375 and since I was paying for the labor anyway it made sense to get a pefect fit.
Old 01-03-2003, 07:26 AM
The defrost vents are actually metal slots in the dash. I cut mine so that the air would be a little more deflected correctly to work with the new dash. I DID NOT cut a all the way across, just the two vents that are there.
Grady aka plain fan
01 996 TT -
Old 01-03-2003, 10:13 AM
