Fast Flashing indicators 73 T
Hi guys just to run something past your brains , the indicatos are working on all four corners but flash faster than they should . On the gauge the left hand arrow flashers the same speed as the turn signals but the right side the arrow flashes the same speed as the right turn signals but at the same time the left flashes too. When i use the hazzard lights they all flash at the correct speed so its not the bulbs right??? i may change all of them just to be sure .... Your thoughts pelicans.......................................... ............
jonny |
Member 911 Anonymous
Are the bulbs incandescent or LED?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
incandescent
hmmm, and all light work, maybe the flasher relay may be going out?
I am not sure about the US version but the Euro version has side marker indicators as well as the main bulbs. I resolved similar problems by changing from cheapo Narva bulbs to not so cheap Hella bulbs and making sure the side indicator mini bulbs were functional. Seems the flasher and the gauge indicator lights are dependant on the correct current load, well it worked for me.
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
If they were working correctly with the bulbs you have but arent now it is
likely the flasher relay
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
I will give the relay a shot and report back , where would I find the turn signal relay ?
Cheers Jonny |
Behind the gauges and you can also see it thru the frunk
Hi guys so an update so far the relay clicks fast when the turn signal indicator is either on left or right . However the same relay clicks as it should when on hazards lights . ....??
Anyone |
Burned out bulb or bad ground
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
So all the bulbs work but I may change them anyway I have cleaned the ground that are on my rear bumper quarter bolts I haven't done the front yet ?
If cleaning all the earth points does not solve it then try adding additional load to either side with a clip on test lamp. You can make one up with a 10W 12V bulb and clip leads. If that slows the flashing then you know your problem. (Its easy to clip on at the fuse panel)
