How do you tell the regular A caliper from the wide A-caliper?
I know the wide ones take a larger rotor, but is there a "tell" on the wide A caliper in marking or measurement?
The wide a caliper has a wider spacer between the 2 halves.
Strip in the middle of the halves?
Yup
OK - got it. Thanks!
Approx 11mm on the wider Carerra caliper
Found a pic of the spacer...http://forums.pelicanparts.com/uploa...1472467253.jpg
Thanks guys
Wait, don't all the A calipers have a spacer?
Wide M rear calipers have a wider spacer and a larger diameter piston than the regular M calipers. |
| All times are GMT -8. The time now is 08:24 AM. |
