Dumb question of the night
I'm tired and confused, but I'll ask anyway.........
What size Fuchs do I have if I have the following tire sizes:
P205/55ZP16 (front)
P225/50ZR16 (rear)
They're Dunlop SP Sport 8000's
Michael
'98 Boxster in Ocean Jade Metallic
Old 01-01-2003, 07:52 PM
SCWDP- Shock and Awe Dept
surflvr911sc's Avatar
Could be 7&8X16 but I would put money on 6&7X16 since that's probably what it came from the factoy w/.
Ryan Williams, SCWDP
'81 911SC Targa 3.6
'81 911SC Coupe 3.2 #811
'64 VW Camper Bus, lil' Blue
Old 01-01-2003, 07:55 PM
If you need to be certain (and you should if you're tire shopping) any good tire store should have a wheel caliper, it will only take a moment for them to determine the wheel width.
Jerry M
'78 SC
Old 01-01-2003, 08:03 PM
Pre Registered
tchanson's Avatar
On an SC, most likely 6's and 7's, assuming stock sizes were retained, although the factory also used 225/50's on the 8" rear Fuchs that came standard on '89 cars only.
Can you post a picture? Would be easy to tell at a glance what Fuchs widths are.
Tim
Old 01-01-2003, 08:21 PM
RETIRED
Joe Bob's Avatar
yup...most likely 6s and 7s.....pull a wheel and look at the serial numbers inside.....
Old 01-01-2003, 09:04 PM
The rears are definitely wider than the one's that come standard, so I guess they're likely 7's and 8's.........The 9's were used on the Turbo's, right?
Michael
Old 01-02-2003, 10:42 AM
twin plugged targa's Avatar
8's were also used on the turbo.
Have a look on the owners gallery to be sure for the fronts.
The 6's do not have the sme deep dished look of the 7's- they are quite diferent.
rgds Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001
1984 Carrera 3.2 IROC RSR look
Old 01-02-2003, 11:25 AM
Mark Wilson
Guest
Posts: n/a
Michael, if this is your car, the backs are probably 8's or 9's and probably 7's for the front.
Mark
Old 01-02-2003, 11:33 AM
Cool
these are 9in.. the 911 belongs to a Calif. member...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-02-2003, 11:43 AM
911 user
Milu's Avatar
Didn't the SC come with 15" as standard?
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 01-02-2003, 11:49 AM
RETIRED
Joe Bob's Avatar
16s were a common option, but 15s were standard.
Old 01-02-2003, 12:45 PM
