Is there any history of 915 gearboxes cracking their casings?
Today whilst underneath the back end stripping breakes and rear suspension I spotted something on the gearbox that appears to be either a casting mark or a crack!!!!!!! There is no oil leaking which would point to a casting mark. The car has never had accident damage. What are the comments? I will enclose a photo later. |
There was a recent thread on this. If this is what you are referring to, Wayne says it's ok.
Spider-webbing on case, casting artifact, or should I be really sad? |
here's the photo - if you look at the web on the casing in the 9 o clock position - there is one web above it and the mark in question is just above that
Platinum Member
I believe if you clean it off and look real close, you will find it to be in the casting and not a problem. I've seen it before on a friends '84.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Ug - I've never seen rust like that under a 911! The only car I've had with rust like that was my '54 bus, which came from Sweden!
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
And this car has never seen a winter!!! - Who said 911's don't rust?
