procedure for clutch cable adjustment 915
Hi
I'm struggling with the procedure of the clutch cable alignment (1982 3.0 SC Targa 915 gear)
See picture: Is it normal to do the adjustment with the spring turned to the right (near heatexchanger)? If so, is it normal that it will never go back to that position when I engage the clutch pedal a few times?
Thanks in advance for some advice, guidelines
(by the way: I have the Wayne Dempsey handbook and carefully (tried to) follow the guidelines described.
Regards
Bas
Old 09-04-2016, 12:55 PM
