-   -   Stuck in 4th... Another stuck 915 thread (http://forums.pelicanparts.com/porsche-911-technical-forum/927994-stuck-4th-another-stuck-915-thread.html)
unclebilly 09-05-2016 07:06 PM
So I was out for my first drive in the 911 in about 3 years (I take it out at least once per year - I usually drive one of my turbos)...
As I was downshifting from 5th to 4th, it jammed in 4th. It works fine but I only got 4th.
Any ideas before I drop it (might be a while before I get to it)?
gomezoneill 09-06-2016 07:20 AM
Make sure all your linkage is in order if it is then drain the oil and remove the inspection cover from the lower r/s (facing the front ) Inspect the bolts they work loose sometimes.
