I hear the POC guys use special shortened torsion bars to get even higher rates, since coils are not allowed in the class.
This is how mine looks lowered.
http://forums.pelicanparts.com/uploa...1473306247.jpg 21/28 torsion bars Polybronze bushings in the rear ER spherical bushings in the front Bilsteins re-valved to match torsion bars w/ digressive curve Turbo tie rods with adjustable bump steer tie rod ends Spindles raised 25mm ER strut brace Adjustable rear sway bar drop links Car is on 16" Fuchs but I intend to get a set of 17's one day. I have kept the stock sways for now. That is probably a future item. As long as you don't intend to go too low, you can get good enough results for street driving for very reasonable money. It depends on how far down the rabbit hole you want to go. I love how the car drives now but the nerf bars scrape if I am not careful. |
Hey everyone!
In case anyone needs technical info on lowering their 911. I've attached a link to one of our tech articles that goes into detail about the pros/cons and overall specs. Reference this at will and best of luck to all! Lowering the 911 Tech Info. - Lowering the Porsche 911 | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article -Dmitry |
Tim... would like to see profile pic of your car if you would post pls. |
Karl,
Here you go... It's hard to see at a distance with a black car because of the lack of contrast so I took a couple of close ups. http://forums.pelicanparts.com/uploa...1473376471.jpg http://forums.pelicanparts.com/uploa...1473376533.jpg http://forums.pelicanparts.com/uploa...1473376559.jpg http://forums.pelicanparts.com/uploa...1473376598.jpg |
http://forums.pelicanparts.com/uploa...1473440461.jpg
This is my SC. Lowered to 24 1/4 f and 24 1/2 r with 22/29 torsion bars, carrera sway bars, bump steer kit and stripped 300 lbs out of it. I did all this years ago when I was tracking it a lot. It is fun on the track and back roads but not very fun for daily driving. The ride is stiff and it's quite easy to bottom out. Dave |
| All times are GMT -8. The time now is 03:07 PM. |
