New User
Copper-Nickle-Iron brake line kits.
Anybody have any experience with these Cunifer brake line copper-nickel-iron alloy kits? They are all to length, already flared with the fitting and numbered for easy install. You have to bend them to your old profile.
Looks interesting (and they are British don't you know... the Queen has them on her outlaw 911 )Cunifer Brake line kits Cheers. -Kav. |
Fleabit peanut monkey
I use this "type" line which bends easily for everyday cars. Your link says theirs is 0.028" wall thickness. Mine is not. More like 0.020", bought from Advance Auto. However, a magnet does not grab it.
I spend $40-50+ for a 25 foot roll and that will not do a full car. Bend, cut, flare, repeat (more than once if a screw-up). Lot's of toil and some return trips for the correct fittings. Some jobs are a piece of cake. Some are horrid. Never a return, though. They want $140-ish for the 911. I see that as a bargain with all the skunk work figured out for you. Read up on bending. The 180 degree bends give you one chance to make it pretty. Then the malleability is compromised.
1981 911SC Targa Last edited by Bob Kontak; 09-08-2016 at 12:55 PM.. |
New User
Cheers. -Kav. |
New User
They have a video on the 911 installation.
Cheers. -Kav. |
Watched it. Cool.
I say two weekends to complete unless you are experienced at this specific job. Spend money on very good line wrenches. Ebay has used MAC wrenches that will pull your "ask" out of a fire. About $10 per for MAC or like quality. $15-20 for Snap-On. Inquire if you can buy "one-off" lines in case you screw up. The one over the trans looks challenging even with a lift. Be patient. This is a big job. Hope someone chimes in on line quality experience.
1981 911SC Targa Last edited by Bob Kontak; 09-08-2016 at 02:31 PM.. |
I did brake lines on a Datsun race car once. I had a terrible time initially, with the flares and lots of leaks. I found out that the cheap flare tool was not the right tool for brake lines and there is 3 different thread pitches for brake line fittings, I think 2 metric and one US.
Once I figured out the correct fittings and the correct flare it was not too bad. On a race car you don't have to worry about how pretty and tucked up it is so an apple to oranges comparison for OEM fitment. I think with your attention to detail you will have no problem with the task. I second Bob's comment above that you should be prepared to mess one up, order a replacement and do it over. No big deal, you have the time :-)
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
