New-ish 911SC Targa Owner
pampadori's Avatar
Exhaust hardware question
Seems like an insignificant part, but...
I have researched a little and decided to use stainless exhaust bolts so as to not rust away within a few years. I read that I shouldn't use stainless nuts with them, but maybe copper or silicon bronze.
So is there a benefit of copper or bronze over the other? Does our host offer them? Couldn't find them searching the webstore myself
Thanks for any guidance!
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 09-09-2016, 08:26 AM
OffCamber00's Avatar
I use copper nuts that i sourced from ********AZ
Mat P
1988 911 Carrera
Old 09-09-2016, 08:40 AM
What?
Eric Hahl's Avatar
Copper for sure.
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 09-09-2016, 08:44 AM
pampadori's Avatar
Eric, any explanation on that? Bronze is copper with tin added resulting in an alloy stronger than both (i learnt myself with google). But does the added tin make it gall the threads easier or something?
I've found bronze but can't locate copper nuts at mcmaster.
Bronze m8x1.25:
McMaster-Carr
Old 09-09-2016, 09:11 AM
patz's Avatar
Loal muff shop will have the proper nutz.
Old 09-09-2016, 09:19 AM
tobluforu's Avatar
Just type in copper nuts m8x1.25 and you will get tons of sites that offer those nuts. I get every nut and bolt from e-bay now. Just make sure you use nickel anti-seize.
Old 09-09-2016, 09:26 AM
E-85 sippin drunk
turbobrat930's Avatar
Bronze m8x1.25:
McMaster-Carr
Here ya go. If you need 8mm, instead of 10mm, just give them a call
https://www.ebsracing.com/product/exhaust-nut-muffler-to-heat-exchanger-10-mm-oem-99908400202-porsche-911-1965-1974
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 09-09-2016, 10:06 AM
What?
Eric Hahl's Avatar
Either is good but copper is better, they deform and are easy to remove after many heat cycles. Our host sells them.
Eric Hahl
Old 09-09-2016, 10:09 AM
gtc gtc is offline
abides.
gtc's Avatar
I've never had a problem with stainless nuts, bolts, and washers on my header to muffler connections.
Graham
1984 Carrera Targa
Old 09-09-2016, 10:43 AM
