Brake light blowing fuse
Happy New year all...
As the new year comes in, I am having my first new year problem! My brake lights keep blowing their fuse? Any body have a suggestion? '85 911
'95 Carrera 4 Cab '87 Carrera 3.2 Targa ‘85 Ferrari 308 - euro ‘80 Corvette L82 Formula 42 - Bad Company |
Super Moderator
Almost certainly has to be a short. When you hit the brake, the power to the brake light bulb is shorting to ground before it hits the light itself. Trace the wire from the switch back to the brake light housing. Look for fraying and expecially where the wire routes over/under/through a metal area.
Chris ---------------------------------------------- 1996 993 RS Replica 2023 KTM 890 Adventure R 1971 Norton 750 Commando Alcon Brake Kits Last edited by cstreit; 01-01-2003 at 01:26 PM.. |
I usually assume in a reply that the questionare guy always goes thru the basics.. like bulb sockets, etc.. it's not always the correct reply, but that's my problem..
so I'm w/Chris on this one, generally speaking.. and if I lose patience searching for the short I'd get one of those "Short Finder" gizmos.. that cost about $25.. one part goes into the fuse location and the other part is held close to the wires and gets triggered when close to the short.. sometimes German electrics is a PIA.. like the fuse buss causing problems. so I keep reminding myself that I'm working on a museum..................Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Make sure you check the wiring for the third brake light. This can be pinched/frayed and has caused several people to keep blowing brake light fuses.
Dan Tolley 1987 911 Coupe The Owner's Gallery 2006 Audi A4 3.0q Cabriolet 2003 Ford F-150 XL Lumber and Trash Hauler. |
I had the same problem with my reverse lights. It turned out one of the wire terminals worked its way loose and was contacting the metal back to the brake light housing. It might be worth looking at before you spend a bunch of money on fuses!!!
Jason F-15 Crew Chief (21 years) '86 944 '71 914 (Sold) '79 911 SC (Sold) |
Buy them, sell them
Do you find that the corresponding front park-light has problems too? They run on the same fuse (at least they do in my old 2.7, I haven't looked at the Carrera).
My '76 had a similar problem after re-assembly from the Panel-Shop, but my front park-light (same side) kept blowing the same fuse. I pulled the front headlight to find the park-lamp incorrectly wired. I swapped the terminals and then re-sprung the rear brakelight (on the same side) terminals. Solved the problem! Hope yours is as easy as mine was.
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
Art,
If you disconnect the 6-pole bulkhead connector on each side of the body for each hamp housing ... you can test for shorts on each side. Sometimes the housings collect ater and mud ... and shorts develop at the back of the sockets. After disconnecting, it is very easy to remove the housings from the car, and clean up years of mud and dirt inside the lamp housings and within the wiring harness. Sometimes the rubber drain fittings get clogged, too, and need to be cleaned or replaced!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks guys...I just finished-up snooping around and may have found the problem or a potential problem! It is hard to trace the wiring, since I am a new Porsche owner and I am a litte reluctant to start pulling things apart (I have to buy the Bently service manuel). Behind the passager side rear well were two wires that looked like they been rubbed by the wheel and the copper wiring were exposed...and since this is the first time the car has been in the rain, since I owned it ....I am hoping this was it...taped it up and hope it holds. Now my question is - do these two wires have anything to do with the brake lights???? Also my brake lights and cruise control are on the same fuse...crusie control is not working on car.
I think the wires you described, are the ones used for a European rear foglight. I could be wrong though.
Car is US spec'd...no rear fog lights
I understand. But my US spec SC has a similar/same wire, and it is for a rear fog light. Or so I have been told.
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Come on guys..... can't anybody give me a definite answer??? The two wires coming out of passenger side wheel well and going towards the rear are for...........?
help!
oil tank...rear fog lights...brake lights....now I am confused!
