ASE Master Tech - 35 yrs
larrym's Avatar
Question 3.2 dme chip ID?
i recently opened up a dme that i bo't as rebuilt from Valley European (Van Nuys) long time ago
the chip appears to be aftermarket - there was a hand lettered sticker on top of the chip "3.2 OEM E54117"
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 10-30-2016, 03:57 PM
88 Carrera, Guards Red
azhodge's Avatar
its a programmable eprom. not original my any means. run away....
Old 10-30-2016, 08:12 PM
Diss Member
Quicksilver's Avatar
The actual printing on the chip will never tell you what is on the chip. They are freely available multipurpose chips. What is programmed on it is the important part.
The sticker over the glass is there for a reason. If you shine enough UV light into the chip it will erase it. It takes a BUNCH of UV light but why chance it? Definitely don't leave it out where it is exposed to direct sunlight.
Because the chip is a 100% unknown it might be nice to get a stock chip to sell it with.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 10-31-2016, 10:51 AM
larrym's Avatar
Smile solved - thanks
thanks - that's what i figured - just wondered if it looked like a known chip-supplier's product
The sticker over the glass is there for a reason. If you shine enough UV light into the chip it will erase it. .
Old 10-31-2016, 05:04 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
The only way to tell is to read the chip and compare its contents to the stock programs. That way I can tell if it's an exact copy of a stock chip or whether something (maps, rev limit) was modified.
Sometimes rebuilders remove an unknown chip and put a copy of a stock chip in. That's what the first part suggests. But the numbers don't ring a bell.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 10-31-2016, 09:19 PM
