Exhaust Valve Pic…….what does this mean?
I took my heat exchanges off to get them cleaned up and repainted. On inspecting the valves, I found cylinders 1-5 all looking dry as in the first pic. 6 however, looked a little "oily" and I could wipe a slight oily film onto my finger (see pic). Does this mean something bad is up with 6? I do get a very slight weeping of oil from the valve cover nut right below 6. My oil usage is very low.
Air Medal or two
If your comp / leak dwn numbers are close, call it good enough !, Unless you want to open pandora's box ...
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between Last edited by afterburn 549; 09-10-2016 at 08:17 AM.. |
Reiver
That looks more like a bit of a rich burning cylinder...is it carbon or oily? If oil that isn't bad either.
De Oppresso Liber Strength and Honor 5th Legion |
Almost Banned Once
Just put it back together and drive it.
I get why you're concerned but don't get bogged down in the details. No two cylinders are the same.
- Peter |
Functionista
Just had my exchangers off as well. All cylinders looked fairly uniform to me. If this is a CIS car I'd check injector spray pattern/leaking/equal amount compared to other cylinders etc. What did the plugs look like?
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. Last edited by manbridge 74; 09-09-2016 at 08:07 PM.. |
Do a leak down, numbers may indicate a worn valve guide.
