Gordo2's Avatar
Thoughts on heating trans fill plug
Greasy hands at the keyboard,
Swapping tranny fluid, classic stuck fill plug. Thoughts on heating it?
Kind of concerning to me considering the flamables.
Quick replies appriciated hope to get it done tonight.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 01-02-2003, 08:34 PM
Gordo2's Avatar
Oh Well
Heated with no luck,
Looks like PB Blaster overnight then to a shop where I can get it up and stuff out of the way to really get at it tomorrow.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 01-02-2003, 09:08 PM
Cool Re: Thoughts on heating trans fill plug
tranny oil will not easily catch fire..BUT it may.. so there is a danger.. the easiest way to set tranny oil on fire is to dose it with some gasoline.. then set the gas on fire first.........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-02-2003, 09:14 PM
usurpah's Avatar
Can you increase your leverage before trying the heat treatment? Mine was stuck and wouldn't budge. Got the car about 6" higher, added a 18" pipe to the end of my breaker bar, and it cracked free.
Also sprayed some juice in there to loosen it up.
Eric C
'88 911
'14 Cayman S
Old 01-02-2003, 09:38 PM
makaio's Avatar
LIke Ron said, the flash point of tranny fluid is pretty high, and it would take a lot of concentrated heat to set it off. Hopefully the penetrating oil will do it's magic, if not try to get a cheater bar in there lik Eric said.
Old 01-03-2003, 06:45 AM
Send a message via AIM to NoLift911
From the been there done that department:
I had this with my 84...both plugs were stuck. The bottom one was a ***** to say the least. Wound up drilling it out and picking the metal out of the threads. Not reccommended.
Heat is good. I used a full can of MAPP gas...everything was glowing...plug came out.
Heat works...don't worrie about the flames if I didn't catch mine on fire you should be fine.
-Jeff
nolift911@hotmail.com
Old 01-03-2003, 06:51 AM
beepbeep's Avatar
Been there: heat, heavy-duty socket and breaker bar.
I hope you didn't drain tranny first.
Thank you for your time,
Old 01-03-2003, 07:14 AM
