87 Carerra, 3.2 liter en
Can't Find Ground
I have a 1987 Carrera. I have done a lot of research on this forum in trying to locate my ground points throughout the car. Several of the forum members spoke to a ground point behind the battery. For instance one member wrote: My 87 has 1 ground coming from neg. side of battery to the front fender. Pull the battery and its right there. Ground from battery might be 8 inches long. When I checked the ground, ohms, on injector connection, my meter was around 14k ohms."
I have pulled my battery and there is no ground point or wire. I have checked for this over and over. Can someone please direct me as I need to find all ground points to deal with a no-start issue
Also, does anyone have a picture of the various ground points. I have the diagram that shows the ground points it is simply an illustration and not a photo of the different grounds. I am not mechanically inclined and so I really need to be able to see what the ground points actually look like so I can check them
Thanks so much
Old 09-11-2016, 11:22 AM
non-whiner
mreid's Avatar
Follow the negative (-) battery cable. What is it connected to?
"Too much is just enough."
Old 09-11-2016, 11:35 AM
Chain fence eating turbo
My 87 has a ground to the inner fender, not the fender itself. If you can't locate where it terminates, it must have been modified AFAIK??
Old 09-11-2016, 12:11 PM
Use common sense......
Follow the above suggestion or post a picture of your battery. Could you crank the starter?
Tony
Old 09-11-2016, 12:21 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks so much
Hope this helps.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-11-2016, 02:15 PM
My Odyssey PC925 install
Follow the ground cable, see last 2 pictures. Look under the mess of cables and windshield washers hoses.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2017 VW Golf TSI
Old 09-11-2016, 02:22 PM
non-whiner
mreid's Avatar
Dude, that is your ground post.
Old 09-11-2016, 02:49 PM
BFT3.2's Avatar
______________
'88 911 Coupe
'85 380SL Benz -Euro
Old 09-11-2016, 03:19 PM
M4reid & BFT3, as well as everyone else:
Thanks so much. I got it now---Like Duh!
Sorry for the crazy, stupid question---but like i said, I got it now
Old 09-11-2016, 04:34 PM
Since we are on the subject of grounds, anyone know what/where points #13 (XIII) and #14 (XIV) are? Are they part of the taillights? I ask because I have an intermittent turnsignal indicator "weirdness".
Weirdness = Several times now, at night, with the lights on, my turnsignal indicators have been sort of illuminated all the time. They still flashed when I used the turnsignals (not sure of the turn signal lights them selves though). Last time, I drove 3 miles with this problem, stopped for gas, when I started the car again problem gone. My first step to try and address this problem is check all the ground points and fuse/fuse contact points. Car is a stock 1976 911S.
Who, What, When, Where, Why and How.
Old 09-11-2016, 09:27 PM
Text me.828-230-0788
Joe Bob's Avatar
I had a brother in law so stupid he couldn't find the ground, either.....
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 09-11-2016, 09:57 PM
