-   -   Help identifying this wire near Trans (http://forums.pelicanparts.com/porsche-911-technical-forum/928669-help-identifying-wire-near-trans.html)
franklinstower 09-12-2016 10:13 AM
When I pulled my engine, I found these wires (Green wire and White wire) tied up by the heater flapper box. The wires must have hit the exhaust at some point because they are melted pretty good. This was done by the PO.
Any ideas on where they should go (1978 SC)?
Thanks,
http://forums.pelicanparts.com/uploa...1473700324.jpg
T77911S 09-12-2016 11:36 AM
speedo?
timmy2 09-12-2016 11:53 AM
Do you have auto heat?
Otto H. Wegkamp 09-12-2016 01:01 PM
Does your oil level sender work? If not, check oil level sender in the oil tank, in the fender. The sender is wired with green and white through a multi-pole connector near the right tail light. The wire is routed in the right of the engine compartment, on the chassis under the oil filler neck.
Otto
franklinstower 09-12-2016 03:19 PM
Speedo works just fine, so do all my gauges. What is auto heat Dennis?
I have not checked the rear defogger....
