3.6 in a 3.2 G50 Carrera? Is it worth doing?
Nothing imminent, but I've been wondering about where to go next with my car. I've modded the suspension to my liking (22 and 29 T-bars, bushings, Koni Sports, lowered, balanced, etc.), but have done nothing to increase hp (except running a cat bypass and an Autothority chip that the PO installed).
Here's my question....does it make sence to consider a 3.6 swap into a 70,000 mile 89 Carrera with G50? The weight advantage of converting an early car does not apply here it seems (car is about 3010 lbs wet with driver). I don't care to spend $3-4k on SSI's, muffler, MAF, etc., only to gain 10-15 hp.
It seems the swap would be a breeze considering the G50 transmission, Motronics, etc....is this true? Just wondering if it's even worth day-dreaming about.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 01-03-2003, 02:46 PM
Mikkel
Guest
Posts: n/a
I've driven a friend's 87 911 with 993 (272HP) engine a couple of times. It feels smoother and stronger than my euro 3,2 no doubt about that. I don't know how easy/complicated the transplant were, but the whole package felt very well put togheter.
Old 01-03-2003, 03:14 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
I have seen a 993 transplant in a 964. The owner said it was a big improvement over the original 964 motor...and it was a very clean install.
It was done by speedster94 and I have some of the images and details on my website if you would like to take a look.
993 transplant
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 01-03-2003, 03:27 PM
Kevin Stewart's Avatar
Hi Im currently doing a 3.6 in a sc, you will probably need every part i need, including the harness the brain, and you will also need a fly wheel, your heat exchangers will work, but i think that is about it, if your car is a 70000 mile car and is exceptional condition, i think i would pass on the conversion, You might spend some of the money just making sure all the service is up to date, or just fix any gremlins it may have, Kevin
Old 01-03-2003, 03:47 PM
