MFI thermostat connection
What do people connect the hot air side of the MFI pump thermostat hot air
input to if you have a straight racing exhaust without heat exchangers? thanks -phil |
You need to go to a manual screw.
The stock heat exchangers have a tube which feeds hot air to the tube. You could also fabricate a small heat exchanger around the collector.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Functionista
Years ago I read that the factory would use a small bulb under the thermostat in an enclosure on header equipped race cars. I believe it was Roland Kunz who relayed this info. I don't believe he has posted in years.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Functionista
And of course Supertec sells the cable actuated enrichment lever set up.
you remove the thermostat and build and aluminum plate to cover the area. Duplicate the base of the thermostat housing.
Drill a hole in it for a 6mm screw, install a steel helicoil. INsert a 6mm bolt and use this to adjust overall mixture of the MFI. I did this years ago on my 2.7 and it is a great mod. Just remember that you have to push the lever in with the screw or the MFI will run way rich like a cold day!!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
I will give supertec a call -- I have the handbrake choke lever unused ...
