To be honest Peter, I've had these flipped flange 993 HE's (by Ben) and one of his back boxes (2 in 1 out) in my cave for over 10 years!
There's many reasons why I haven't fitted them nor had the car registered for most of that time, including much fiddling with motorbikes. I've finally finished all of my bike projects and now have a wonderful amount of space in the cave and the car is now accessible. Engine is now on the stand and tranny on a dolly. It's all been powerwashed and parts are now being sorted for media blasting, cad/zinc/plating & powder coating, including brake calipers. I won't hiijak this thread anymore but hopefully in the coming months we'll have another opinion on the 993 HE, heater backdate project on an ROW 3.2. Love that Oxley! I'm up that way at the moment with one of my bikes. I can't wait to run it in the Carrera! Thanks Safe. My main concern is giving up that beautiful fat powerband for some top end without changing cams.
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Good score Shirish!
Look forward to hearing about your experience with them.
Thanks Phill, i hope they work out - will keep the thread updated.
Shirish 1987 Carrera, Granite Green |
Yes, I forgot about that conversation! I did actually did check out the price for the F model heat exchangers only and recall they weren't much cheaper than the full system. The cost and the fact that I couldn't see how they would neatly integrate with the 3.2 heater air supply scared me off. Great luck with picking up a pair at a good price and I do look forward to seeing your results. I know I am banging on about the hot air ducting in particular but I want my build to be low key looking and with only the observant noticing the subtle changes. Last edited by Peter M; 09-08-2018 at 05:09 AM.. |
I reckon bolt them on after your engine is detailed, give them a run on a dyno to check the AFR and if that's OK, don't look back, just drive it! ![]() If the AFR is out, at least you have something to inform Steve Wong of the changes you need. I can't see any sense in you using anything else than what you have already. PS: I can't wait to get my Carrera on the Oxley either! |
Please post pics of yours as and when fitted, I’m keen to see pics.
Mines all fitted up but I'm about 3 weeks or so away from seeing it again as it's waiting at the tuners to have a Motec M130 fitted and I now live about 400km away. I will have a dyno chart by then too and am keen to compare how our respective engine builds compare, especially finding how much I've left on the shelf by keeping the standard 3.2 intake manifold! Regards Peter |
Shirish have a word with Andy Young on IB. He has just had a full set with the bespoke silencer fitted by Rob at Racing Restorations. Apparently Rob wasn’t impressed with the ease of fitting, lots of extra work. Seems there is a mid range improvement though.
Ian |
Ian |
Bigger "SSI" system
Hi all.
Here is my update on the Eisenmann exhaustsystem with 39mm internal diameter and «freeflow» 2 in 2x70mm out. It did not give more than approx. 1 !! more wheelpower than the old Dansk system. So I set out to find out why. After some thinking and studying I saw that the right muffler outlet had a huge restrictor. A loooong funnel that has only 16!!!mm internal diameter. I knew that to had to go since my engine has RSR Sport cams. So after removing it the result was even 6 more wheelpower, in total 7 more wheelpower over the Dansk system. The engine now works great and has 245whp and 330Nm torque. I spoke with Eisenmann about this and they said that this system was made for an original spec 3.2 liter Carrera engine, thats why the funnel was there. I am happy now and the sound is beyond cool ![]() Here’s a pic of the funnel: ![]() Sent from my iPhone using Tapatalk Last edited by Litle brother; 09-12-2018 at 02:12 PM.. |
How bizarre! Why would a standard 3.2 benefit from that funnel in the tail pipe?
Glad you have seen some improvements. Did you previously have the 35mm ID Dansk SSIs?
Hey Litle brother, how tough to pull out that funnel? Any "grinding" or welding involved? Also, once you pulled it, has there been any drone added? One thing so great about the Eisenmann system is that there is no drone. I would hate to pull this and then find that I have screwed this up. Thanks.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler '07 Boxter |
Sherwood |
Bigger "SSI" system
Thanks ![]() Hard to say why the 3.2 would benefit from that, but it has a much milder cam profile so I guess thats why. Yes my old system was the 35ID Dansk "SSI’s". Last edited by Litle brother; 09-13-2018 at 02:32 PM.. |
Bigger "SSI" system
Hey Lyle. I only had to grind of the welding on the end of the outlet tip. If you look at both the right and left you will see what I mean. Once the welding is grinded of the funnel comes out quite easy. BUT, you WILL get some droning around 1600-2000 rpm. However. I am working on some perforated tipinserts to mend that. ![]() Sent from my iPhone using Tapatalk |
Lyle,
sorry to ask again, but I really would like to hear that system... Any chance for a soundfile? No matter which quality!
87 930 bblk/blk 88 3.6 white/blk |
Hi Falk, just sent you a PM...
83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thread Tools | |
Rate This Thread | |
