AirBorne!
subscribed
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 03-08-2017, 03:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
CARB legal in CA?
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-08-2017, 08:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
hmm, I asked Eisenmann for a soundfile few times without success.
I really would like to install that system, but I am not willing to pay that price
without getting a idea how it sounds.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 04-05-2017, 12:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Hilbilly Deluxe
emcon5's Avatar
Originally Posted by Trackrash View Post
CARB legal in CA?
82 911SC Coupe
GTI Cup #43
Old 04-05-2017, 10:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Tony
Maxhouse97's Avatar
Will someone that is in regular contact with them please ask if they intend to make a simple version of the old school SSI like exhaust with 42mm primaries and thick flanges for Carrera 3.2s? They are not answering my emails 😡
Tony
87 Carrera Coupe
12 991 Carrera (sold)
07 Cayman S (sold - not soon forgotten)
93 968 (sold)
Old 04-21-2017, 07:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Well, I couldn't help myself (header-junkie that I am), and I bought them. In the USA, you have to deal with iND Distribution, a performance system company in Illinois. I started working with Sven at Eisenmann, then Anthony at iND. Response and follow-up was great. I just received the header/heat exchangers; see the photos here. They are really beautiful. I couple of points:
The packaging they arrived in was the best I have ever seen. They were completely "mummy wrapped" in bubble material and then heavy boxed. Great job there.
They have the 42mm tubes. Very nicely done.
You can order any or all parts of the system (headers, CATs, and various muffler options). I am going to start by using my current 2/2 muffler (Dansk w/84mm outlets), so I just need the header/heat exchangers. I forgot, when I ordered originally, to include the connector pipes between the header and muffler. Original SSI didn't need these, because they didn't need a provision for CATs; these do. Eisenmann's system here for the 3.2 includes that option, so to delete CATs you need to include the connector pipes. I didn't realize this until the headers showed up (you can learn from my stupidity).
The heat exchanger connections, and all the dimensions, are compatible with the 3.2. However, if you don't already have the old style oil cross-over pipe, you need to order that also (I didn't need it).
The flanges are actually "thin", though, so you will need to use more standard nuts on the exhaust port studs (not the barrel nuts). No big deal.
I have not fitted these up to my car yet, so I cannot comment about that. I have to wait a couple of weeks for the connector tubes.
No doubt these are pricy, but I want to have a more "authentic" system, and the larger pipes should work much better with my 3.4L motor. Once everything is mounted I will take it to a dyno and get some data to share. In the meantime, contact Anthony at iND and they will fix you up.
https://ind-distribution.com/
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler
'07 Boxter
Old 04-22-2017, 08:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Send a message via Yahoo to Lukesportsman
Sure are pretty. Hope they perform and fit as well as they look. A product we've talked about for a long time.....hopefully it pans out for evey one.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 04-22-2017, 09:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Tony
Maxhouse97's Avatar
Ok great, thanks for sharing. Like that you can purchase without cats. Question is what is the difference between the 3.0 version and 3.2 version (prior to the provision for the cats).
Do you mind sharing your price out the door?
Tony
87 Carrera Coupe
93 968 (sold)
Old 04-22-2017, 01:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
The version for 3.0 is essentially a copy of the classic SSI HE, but with larger 42mm primary pipes. This means the connections to the heater system are easiest with backdated heat (heater tubes connect up through the engine tin and don't use a separate blower, etc.). The 3.2 set up can use the stock aux. blower. See the photo of the "F" series classic version, then you can compare to mine above...
Up to you which version to go with, but the new one gives the option for CATs if desired.
Price-wise, I am all-in at $2900, including header/HE, connector tubes with O2 sensor bungs on both, shipping from Germany, etc.
'07 Boxter
Old 04-23-2017, 05:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
Tony
Maxhouse97's Avatar
Interesting that they stuck with thin flange for the 3.2. Wonder why? I read some threads debating whether the thick flange acted as a heat sink or not, increasing the effectiveness of combustion?
Lyle O - did yours have any type of insert that extended from the HEs into the exhaust port of the head on your engine? I've read about this on SSI's, but it doesn't look like it's there in the pics you sent.
Tony
87 Carrera Coupe
93 968 (sold)
Old 04-24-2017, 08:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Tony
Maxhouse97's Avatar
There was also a concern about not having the right amount of clearance with your muffler if you used thin flange SSIs on a 3.2. I wonder if Eisenmann has adjusted this between their SSI look alike for the 3.0 and the 3.2 system they just created.
Tony
87 Carrera Coupe
93 968 (sold)
Old 04-24-2017, 08:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
WOW very nice. I make a 1.625 setup for 914-6's and charge $2200 retail and mine are not stamped. These look great. There is a huge cost in tooling up for these. good for them.
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 04-24-2017, 08:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Ben
Old 04-24-2017, 08:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
There is no "insert" at the outlet. I will say, though, that I do not remember an insert on the "thick flange" SSIs I had a few years ago (but it's been a while, so they may have been there).
As to fit, I haven't tried to mount them up yet, so we shall see (need to wait for the connector pipes). But from the earlier posts in this thread, they had this system specifically designed/modified for the 3.2, and there are photos showing it mounted.
'07 Boxter
Old 04-24-2017, 11:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
gtc gtc is offline
abides.
gtc's Avatar
That is pretty cool that the 3.2 version is designed to retain the heater crossover tube. But I suspect that would restrict your choice of mufflers somewhat.
Graham
1984 Carrera Targa
Old 04-24-2017, 12:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
tobluforu's Avatar
I know this is somewhat apples to oranges here, but I remember buying ssi's back in the day and paying 750, and I thought it was way too expensive.
Old 04-24-2017, 01:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
I thought thick flange was ONLY to take standard 38mm id SSI's and mate them to 42mm exhaust port of the 3.2. No heat sink or anything fancy, just to account for the fact that the exhaust outlet was too big and they were not about to retool for that.
Old 04-24-2017, 06:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
They also had the lip called gasket protectors to prevent exhaust leaks
Ben
Old 04-24-2017, 06:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
DG624's Avatar
These exhausts look nice. They have the option for CATs or pipe for racing. Will the thin flange be a problem and can they be enlarged? I think the new CATs with high flow would be almost as good a straight through...see GRM article on mufflers. Lyle, the pictures are different where the heat hooks to the exhaust...is this for the later model cars?
Old 04-25-2017, 01:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Using copper plated nuts, they should mount right up.
Yes, this is designed to mate with the 3.2 heat set up: you use the standard heat cross-over tube to connect the two outlets, which combines to one tube up through the tin, to connect with the aux. blower. This is different from the traditional SSIs for SC and earlier cars (no aux blower, and each side goes up through the tin independently).
'07 Boxter
Old 04-25-2017, 06:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
