Has anyone given a dyno report...before and after or compared with just a CAT bypass pipe on stock system? That is the most important information when considering on whether to spend the money. I have been told that the only way to improve on a CAT bypass is with different cams and maybe higher compression.
I just want to prevent you from disaster.....................a friend of me trusted in the German quality , German welds ,
The result is an exhaust with numerous & unsolvables problems , wich not fits at all , leaks , no thick flanges ................... Ok , that's not the same set and not free-flow , just SSI version ,but same brand and for sure , the same welders , i let you appreciate the hight quality of the adjustments.....................and the perfect fitting ............... Just have a look at the pics to see what sort of product you're going to buy , just incredible ; and no explanations , no apologises , just money-back . You have the chance to have M&K exhausts in USA , just not search better for quality in Europe , you'll not find something equal , and that's the reason why numerous 911 owners order at M&K. (or RaRlyL8) ![]() ![]() ![]() ![]() ![]()
LIGHTER = FASTER !!! Last edited by cdrik915; 08-09-2017 at 04:39 AM.. |
FYI, here are the results of a weigh-in between genuine 3.2 thick flange SSI and factory 993 Gillet heat exchangers.
Weighed on FedEx scales: 993, Gillet, 11.9 lbs (24 lbs/pair) SSI, thick flange, 16 lbs. (32 lbs/pair) Sherwood |
Well, time for an update from my venture into this system...
I finally received the muffler, and decided to install the entire system over the weekend. The delay in receiving the muffler (you will recall I have had the headers for some time) was caused by the black chromating of the tailpipes, as Eisenmann has a supplier do that (well worth the wait; more on that later). I spent the better part of Saturday on the install. My observations on that:
This system rocks. For those that need max heat (like I do here in Michigan), there is no better system, as it has the great original HE design, while utilizing the 3.2 heater tube merge. You also have the option to add cats (not for me). It is heavier than the M&K system for sure, though, and it is pricy. For me, however, it is worth every penny to have such a perfectly matched and beautiful system for my car. Even the detail of the black tail pipes is a great surprise; I love the look, yet really have never seen this option on any other system (except for the factory black tip). Also, I must give a shout-out to iND distribution, who are the North American dealer for Eisenmann. They are a real joy to deal with (thank you, Anthony), and were always great with communication and updates (in spite of this being a brand new system). Here are some photos of the system installed. I still owe sound files and dyno results, and I will do both in the coming weeks, and will share. ![]() ![]() ![]()
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler '07 Boxter |
probably the perfect 3.2 exhaust setup
Cool, looks really good!
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. Just works! 911T Coupe -69, 3.6, G50, "RSR", track day. Sorting out issues... 924 -79 rat roddy... 931 -79 under total restoration... |
Lyle, thanks for the great review!
Really would like to see dyno + soundfile.... How do you like the system after first impression? Thanks Falk
87 930 bblk/blk 88 3.6 white/blk |
The more I drive my car, the more I love this system. Definitely more tame at idle than either M&K or Dansk, but still you know it is a sporty system. But at higher revs, it really has a feel and "punch"; it rips nicely. The smoothness, with no drone at all, is amazing. Super satisfied. It looks so good, though, I wish it were more visible! The black tail pipes are really cool, too...
83 911 Production Cab #10
Lyle,
Did they came with the muffler?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Yes, you get an option for the typical polished stainless, or polished black anaodized. They are removable.
They will look good against white.
Lyle, any news for the soundfile?
Falk
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Are there any updates on these exchangers?
I checked out their website and still could not get them for sale. I am quite hoping to get a set, although my build will require me to use a custom built muffler as I need the centre exhaust outlets, so the plan is that I get the Eisemann exchangers, cats and then make a custom muffler to fit. I guess I also will need to make the parts to fit to my "old" (as in pre-84) heating system, but that will just be part of the fun. So any update or link of how to order a set would be great. And then I can sell my original SSI's (new in the box, not the Dansk versions) and hopefully defray some of the quite high cost of these suckers.... Dennis |
All true and the thing that people don't realize that until heat cycled the stainless moves around a bunch..lots of flexibility
Ben 914-6 2.4s GT tribute. 914-6werkshop.com manufacturer of 914-6, GT, Conversion parts |
We have probably had at least 4 different sets of headers with heater boxes on our
modified 3.2: now a 3.5 with supercharger. In terms of "heat", we have yet to see anything come close to heat output of the stock heat ex changers or SSI style (Dansk) aftermarket So, aside from actual header performance, whether that be on a stock 3.0, 3.2 or whatever, you need to consider how cold your climate is. The coldest temps our 911 cab has driven thus far has been 16F. At 16F, the stock 3.2 heat ex changer, without using the rear auxiliary blower in the motor bay, is terrific; just using the two kick panel fan boosters in the cockpit. We are currently running the Dansk version of the SSI for a 3.2's. Have not had clear roads to test temps in the teens yet, however works okay in the mid 30's to low 40's so far. Naturally, performance wise on this modified engine, as you near boost levels, is not so good due to the restriction of the small primary and undersized collector diameter
Kuehl 1987 911 cab, modified https://griffiths.com/ Last edited by kuehl; 12-11-2017 at 07:14 AM.. |
https://ind-distribution.com/product?sku=P91130.WT38
78 911SC Targa, GP White |
Yes, check with Anthony at iND-Distribution. They would handle all North American sales I think.
I just put my car away for the winter (in a nick of time), and I could not be more pleased with the system. Amazing performance and sound. Interestingly, I did some dyno runs and it hit exactly the same peak RWHP as my former system did, though with a different slope on the curve (but different dynos). Unfortunately, I screwed up the sound recording I made during the run, so that has to wait until spring. ![]()
Lyle,
Thank you so much for posting your before and after dyno run. It's not often we get good comparison data like this! Just so I'm clear, is the before run with your Rarly L8 1.625 inch headers and M&K 2/2 muffler? Did the AFR change much? Do you have any dyno results for when you first ran SSI's and Dansk 2/2 muffler? Thanks! Peter |
Lyle,
Your before/after results are close. Unfortunately, comparisons on different days/conditions and with different dynos don't provide conclusive A-B comparisons. Or, differences might be so minor with your particular engine configuration, it's a wash as to which exhaust system is "better". Could you summarize the details of the two systems to better understand the before and after? Thanks, Sherwood |
Thread Tools | |
Rate This Thread | |
