Strong raw fuel smell 73 t
Hi guys I have a strong smell of raw fuel in the cockpit but I'm sure it's blowing through from the trunk/area . I have attached a photo of what I think is the problem . The vent pipes is floating loose in the trunk . I have a new fuel pump fitted so it's not that . Let me know your thoughts guys
Old 09-02-2016, 03:54 AM
Could. Plug it and see if it fixes it.
Old 09-02-2016, 04:13 AM
It's a 914 ...
stownsen914's Avatar
When do you smell it? When starting? While driving? Anything else going on when you smell the gas?
Car running OK? Any stumbling or rough running?
Old 09-02-2016, 04:22 AM
wayner's Avatar
It likely happens when the tanks is full of under hard cornering/ breaking??
There is a vent line that goes to a surge tank under the cowl bt the winshield, then back into the fronk to a missing carbon canister
There is a thread somewhere around here showing a vent line schematic
SOLD - 914 wide body hot rod
Old 09-02-2016, 04:32 AM
Hope this tread can help you...
HELP: unknown hole in fuel doorway
RSTarga and HarryD pointed me to schematics.... i think you can find useful the post from HarryD on page two
Old 09-02-2016, 06:01 AM
Vintage Motorsport
RichardNew's Avatar
This might help.
Richard Newton
Is Your Garage on Fire?
Old 09-02-2016, 06:10 AM
The car runs good but the smell is constantly there . Probably stronger when I refill . Would anything happen if I blocked of the vent tube to see if it's that . Is it dangerous ..???
Jonny
Old 09-02-2016, 10:45 AM
I just read fizues reply and there is this picture which is exactly what I have. It looks like I am missing some parts. This maybe due to a new fender but I'm not sure but there is no canister under the front wing. So what are my options , from what I can see the Carbon canister is no longer available new. Has any found a work around for this ?.?!
Old 09-02-2016, 11:01 AM
Old 09-02-2016, 11:03 AM
The car is a Italian delivered car
Old 09-02-2016, 11:05 AM
Italian delivered probably only has a hose from the tank going to the surge tank (nr 1) in the diagram and another hose from the surge tank to the front of the car, so no carbon canister. Check the surge tank under the cowl, mine had a crack which released fuel fumes into the cabin. A new surge tank fixed that problem.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 09-02-2016, 11:58 AM
hi peter when you say to the front of the car can you tell me where it termiates?
Old 09-02-2016, 12:30 PM
Jonnydaz53, our cars should match because both are Italian models and both are 1973 T
(btw, I live in Italy)
If you need some more photos (global view or details) feel free to ask.
Looking at your photo I can tell that your configuration is right (except for the overfill brake fluid tube that should go into the fuel drain hose, yours is missing and you added a bolt there)
Do not worry, you aren't missing any parts. Your car, like mine do not have a Carbon canister system. (and this is common to many VW cars of that era in Europe).
I've checked this informations with Porsche, Porsche Mechanics, and Friends.
Our evaporative systems are simpler than US and later systems.
A vent line from the tank go to a surge tank and then out of the car.
The surge tank has to be at an higher level than your fuel tank because if you overfill, gas has to come out from the fuel dorway (activating the autostop system at the gas station). If the surge tank was placed at a lower level than the fuel tank, if you overfill, gasoline can spill-out from the vent line (never reaching the fuel door way) and flood the gas station floor.
Also, absolutely do not tap any tube, you do not want the tank became pressurized by evaporating fuel gases (the reason seems obvious: if the tank became pressurized it can explode and if your tank explode you will not detect a smell of fuel but a smell of fire and fumes!!)
Simply check all tubes (also fuel lines from tank to the engine) are in good shape and follow Peterfrans’s suggestion.
If you really have to tap the vent line remove the fuel tank cap and do this tests with the least fuel possible and with a big fire extinguisher near you (anyway I absolutely discourage you to do this, it can be really dangerous for you people near you and your car!!!!)
Hope this helps.
Fizeus
Old 09-02-2016, 12:34 PM
fizeus can you show where the tube should exit, i have smelt the tube and it smells of raw fuel surely there must be a better system?
jonny
Old 09-02-2016, 12:50 PM
the hose goes through a grommet (lower left side of the trunklid support panel) and terminates in the open air behind the front bumper
Peter
'13 981S
'73 911T
Old 09-02-2016, 01:05 PM
jonny
Here is a brief write-up image
Green arrow shows tube from fuel tank to surge tank (green square) and red line shows tube from surge to out of the car
tube from the surge tank exits here
Hope this helps
Old 09-02-2016, 01:08 PM
wayner's Avatar
I'd prefer to route it out back if just out
A pal spun his Italian delivered 911 car on surged fuel in a turn
Another race car burst into flames when it spilled on a hot brake rotor
If you need a canister contact Mike's 914s: specializes in the repair, restoration, and maintenance of Porsche automobiles
He has a shelf of them
Old 09-02-2016, 01:11 PM
I seemed to remember I had this discussion some time ago: tank ventilation-MFI diagrams
Peter
'13 981S
'73 911T
Old 09-02-2016, 01:20 PM
A little off topic and not to hijack... it's always a pleasure to read a Grady's post! (We lost a great member and a good man!)
Old 09-02-2016, 01:37 PM
that is certainly true, but nice that still people can benefit from his knowledge through this board. Same goes for earlySman.
Peter
'13 981S
'73 911T
Old 09-02-2016, 01:52 PM
