Shocks
I'm wondering if it is possible to change shocks on a 82 sc without a lift. I have completely stock suspension. Doing it on jack stands if possible? Any advice would be great
Old 09-22-2016, 09:09 AM
Why not? Can you get the car off of the ground one corner at a time with a jack?
Old 09-22-2016, 09:13 AM
puddy's Avatar
I did mine really easily using two jack stands under the front torsion bar caps.
Porsche 911 Shock Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 09-22-2016, 09:42 AM
It's actually easier than most cars because your 911 has no coil springs.
Matt - 84 Carrera
Old 09-22-2016, 09:47 AM
Administrator
Dmitry at Pelican Parts's Avatar
Thanks for the shout out puddy!, glad our tech articles made it easy for you.
-Dmitry
Old 09-22-2016, 10:48 AM
Administrator
Luccia at Pelican Parts's Avatar
I changed out suspension on the ground with jack stands once just fine. A lift definitely makes it easier, but it can be done without one no problem. Maybe you can check out the QuickJack for feature projects like this in your garage. Good luck with the install.
http://forums.pelicanparts.com/porsche-911-technical-forum/905491-free-ground-shipping-purchase-quickjack-lift.html
Old 09-22-2016, 10:52 AM
suckho's Avatar
No need for lift. The tricky part was to get all stuck parts off
Porsche 911 SC Coupe (1982, RoW, Zinnmetallic)
Old 09-22-2016, 11:34 AM
Thanks everybody. My friend who is a Porsche tech made it like it's impossible without a lift. Add that to the liist of winter projects
Old 09-22-2016, 12:27 PM
wrxnofx's Avatar
Sounds to me your friend should make up for his bunk advice by letting you put your car on his lift.
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 09-22-2016, 02:24 PM
It's easy on jack stands... no worse than doing brake work. Just make sure it's stable before you get under it.
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 09-22-2016, 06:27 PM
more fun cleaning all the old oil out of the front struts !!
Old 09-22-2016, 08:12 PM
Under the radar
Trackrash's Avatar
Has he ever worked on an air cooled Porsche?
I have done suspension work on my 911 many times with jack stands. It's not a problem.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-22-2016, 09:17 PM
I completely disassembled my front and rear suspension and refurbished it while on jackstands.
The rear top bolts are tricky due to the CIS intake being in the way. Get ready to work blind. I supported my engine and did a partial drop to access them.
Old 09-23-2016, 05:42 AM
