Help needed with cruise control wiring (88 carrera)
I could really use some help from fellow Pelicans on the wiring of the cruise control module.
The cruise on my car has never worked, and while I don't miss it, I would like to get it working as a project. PO removed the computer, probably because it was dead, and while wiring for an aftermarket stereo probably figured there was no point in reinstalling a non-working cruise. I'd consider buying a working cruise computer, but want to make sure I'll know what to do with it. Bear with me, on these naive questions. So - first photo and question: this appears to be the two mounting points under the dash, right under the radio, is that correct? ![]() I have seen the parts diagram, which shows a small metal bracket, so perhaps the cruise module does not bolt directly to these points, but requires the bracket?? Next photo and question. I believe the cruise stalk wires are show here in the photo, and these must attach to the cruise. ![]() Last part is the hard part. What else connects to the cruise computer, from this jumble of wires? I believe the cruise stalk, the clutch switch, and the electric servo all have to feed in here somehow, but I need some help in identifying things. This photo shows a black plastic connector, and some brown wires which are all candidates. ![]() thanks!!
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
I have an 87 carrera, not sure if the same as an 88, but will take some pictures this evening for ya.
Cool ,thanks. And even partial answers are welcome!!
C'mon, someone has to have some experience with cruise control wiring on a late 80s Carrera, I could use any nugget of info...
thanks-
yes there is a bracket, and there is a little box (CPU) sitting under the radio. i have never taken off the plastic cover on the end to figure out how the cables are connected. mine is working and in a place like Oz whith all these ridiculous speed limits it actually works quite well to keep me out of trouble.
![]() let me know if you can't find anyone to get you the info, then I'll have a closer look & take some pics.
cheers hg 1988 911 Cabrio |
Thanks geoz - I think a few pictures would be very helpful, and at least help me get things oriented.
Recreational User
There's no separate bracket. There are two bracket "ears" riveted to the sides of the box, and are used to mount it to the two mounting points in your first picture with machine bolts.
All electrical connections are via a 12-pin plug on a wiring harness that should be hanging in the vicinity. It looks a lot like that small connector in your last pic, but bigger. I've been under there a thousand times and that small connector doesn't look familiar to me. Hopefully it's not a broken 12-pin cruise control connector. |
Undocumented User
+1 one the 12 pin. If it's not there, then give up now.
The other connection goes from the stalk to the wiring harness which then feeds into the large 12 pin. But if I remember correctly, it's a circular (white) four pin connector. I'm just going by memory since I recently took mine out. There is nothing else connected to the computer, separate source of power ect. |
Okay, does the second photo look like the white connector coming from the stalk?
Megerian -- I have an '88 and will take some pix to see if it will help out. The cruise computer is still installed and the wiring is still factory (along with the stereo). Give me a few to get the pics.
************************* Socbum '88 911 Coupe |
SEARCH FUNCTION! Lots and Lots on cruise control.
This may help but there are many other threads. Cruise Control Repair
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera Last edited by kodioneill; 04-26-2012 at 10:46 AM.. |
I used the Bentley schematic on pg 970-62 for my initial troubleshooting. Ended up that when I replaced all my brake light bulbs with LED bulbs I lost the "ground" that the computer was looking for when the brake is not applied. Reinstalled the standard incandescent bulb in the third brake light position and the system works great now.
Larry '88 Coupe '66 Mustang Shelby GT 350 Clone (sold) |
For the last two posts, I appreciate the input, but I am not trying to troubleshoot a non-working cruise computer. I am trying to determine how to wire in a new cruise computer, since mine is missing.
Hence the reference to the Bentley schematic.
The box under my dash has a bracket on it and attaches to the bracket in your last picture. The wires that come out of the part you are missing is a wire harness, with no connection, and dissappears. The cruise control computer, per the bentley pictures, is under the hood next to the brake master.
Recreational User
Anyone with an 88 or 89 willing to take a couple of photos of their cruise control computer under the dash??
thanks - I would really appreciate it
Sorry for the delay, i took some pics and will post tonight. The wires come together into a 14 pin wire harness that plugs into the cruise control module. If the PO cut off the wire harness you might have a tough time getting it all back together.
Okay - thanks - hopefully your pix will help make some sense of the wires. As you say, if you wiring harness is gone, I may just punt on this project.
Let me know if these help
![]() ![]() ![]() Let me know if you need other shots.
