How to unplug seat connector?
Just unbolted the front seat, but can't figure out how to unplug the electrical connector without damaging it.
Tips, tricks? Thank you SmileWavy Kees |
You just pull it out.
Look at it from the back of the seat. If I remember right, the connector lifts up. You can pry it with a screwdriver once you're able to see it clearly.
I got totally stuck on this. I was able to get the cable unhooked, but there was a 2nd cable harness that was impossible to detach. In fact, I remember someone else mentioning his cables that were cut and re-connected with a different clip harness, for easier removal, which proved to me just how hard it is to disconnect the seat.
There are details here. http://forums.pelicanparts.com/porsche-911-technical-forum/835738-front-seat-removal-how-do-you-disconnect-power-cable.html |
Thank you all and especially Sugarwood (in my case there was only one cable).
After I removed the bracket (2 screws) it was a piece of cake. SmileWavy Kees. |
| All times are GMT -8. The time now is 07:01 PM. |
