-   -   81 SC Cold Idle Issue (as in will not idle) (http://forums.pelicanparts.com/porsche-911-technical-forum/930111-81-sc-cold-idle-issue-will-not-idle.html)
Mike in FL 09-25-2016 11:31 AM
I've been having a cold idle issue for a bit of time. When cold, car starts right up but after a few seconds starts to get rough and dies. Sooo, I did some pressure checking with these results: 1)System pressure - 73 psi. 2)Control pressure - engine cold and running - 54 psi (!) - engine warm and running - 54 psi (?). Ambient temp during testing - 85 degrees. I have the 090 WUR. With engine cold, as I watch psi build, engine runs fine until about 45 psi or so is reached, then it starts to break up. Specs seem to call for about 36-40 psi when cold. Any thoughts? Btw the WUR is a rebuilt unit - swapping that out for the old one made no difference.
Thanks,
Mike
boyt911sc 09-25-2016 12:57 PM
Wur-090.........
Mike,
When the engine is cold, check the resistance (Ohms) of the WUR-090 including your spare WUR. It looks like both WUR's are out of spec. and your cold idle problem is a typical one when the WUR is out of spec. Keep us posted.
Tony
Mike in FL 09-25-2016 02:37 PM
what should the resistance be with a cold wur?
Bob Kontak 09-25-2016 02:49 PM
26 ohms.
prschmn 09-25-2016 05:05 PM
Wurs came with different heating elements for euro and US spec cars. The US units have a bigger heater and tend to lean the mixture too soon-in the interests of meeting US smog tests.
theiceman 09-25-2016 05:36 PM
define " too soon" . I have a Us spec engine and it starts and idles flawlessly.
prschmn 09-25-2016 05:45 PM
If mixture is on the rich side you can bury the misfires. I'm just saying that since the author
didn't specify whether it was/is a US or Euro spec car the different WUR can be a minor problem
prschmn 09-25-2016 05:51 PM
To elaborate=I used to deal with a lot of Gray Market cars that had the WUR replaced--
and they weren't happy about it. A US spec with lower compression isn't as sensitive.
strictly 09-26-2016 01:57 AM
that sounds very lean (the idle dieing bit) and the specs on the control pressure are a very lean for cold, but just a little lean for warm! You need to set up the WUR for hot and cold (i.e take apart and adjust), check you airflow sensor plate height, and finally reset your mixture. It could also be other things (air leak, etc) but start with the basics.
In particular, start with the air flow sensor plate height (and check for binding) and then the WUR adjust. When you swapped the WUR over, what pressures did you then have? Also suck on the vac line, and watch the pressures change when in warm control mode.
30 to 87a on the fuel pump relay to hotwire it for the tests, unplug the wur heater to start, then plug it in, no need for the engine running. If you are still getting high control pressures when cold, then disconnect the return line from the WUR and run all disconnected lines into a container. Could be a blockage on the return line somewhere or the WUR itself.
Mike in FL 09-26-2016 06:56 AM
Good morning! My car is the US spec - I have an Oxygen sensor. I measured the resistance this morning on the WUR across the two terminals (I guess that's how you do it) - Cold engine - 9.2 ohms Warm engine (10 minutes running) 9.9 ohms. Outside air temp 78 degrees. Based on these, as well as no change in pressure from cold to warm engine, is my problem my "new" WUR? Thanks for the quick and great feedback!
Mike
T77911S 09-26-2016 07:41 AM
the engine is not warmed up completely.
more noticeable on cold days.
same thing with the AAR. it closes too soon.
boyt911sc 09-26-2016 07:45 AM
Wur-090.........
Mike
Mike,
You need a working WUR. You will have this erratic cold idle unless the WUR is fixed and calibrated. I could lend you one for you to use and test. Going back home tomorrow from Sarasota, Fl.
Tony
Mike in FL 09-27-2016 03:01 PM
I contacted the supplier of the WUR that I purchased last year. As it is still under warranty he has agreed to take it back and replace it. It is now on its way to him. I'll keep this thread updated as to the results. Thanks to all for your posts and help
Mike
Bob Kontak 09-27-2016 04:08 PM
Mike
In the interim...........
Find the return fuel line to the tank. Make sure it has no restrictions that could allow fuel to not return freely to the tank.
A partial return restriction can cause your condition.
Originally Posted by strictly (Post 9295388)
tCould be a blockage on the return line somewhere or the WUR itself.
As mentioned. Don't disregard this.
Dave Kost 09-27-2016 06:19 PM
You can carefully crack the return line from the WUR to the return back to the fuel tank, if the CCP pressure goes to spec then you have a blockage in the return line. If not then of course its the WUR. (I put the WUR in a bucket and jumped the fuel pump.) Or, you can also run a long fuel line from the return line port of the WUR to a gas can outside of the engine bay.
Glad to hear the rebuild shop stood behind their work.
Good luck and keep us posted. That's how we all learn.
boyt911sc 09-27-2016 07:11 PM
WUR warranty........
Mike
Mike,
Good to hear that the WUR is under warranty and a replacement is coming soon. Based from your information, there is no flow restriction in your system and the problem is your out of spec WUR. When you get back the new replacement WUR, check the heater resistance and make sure it has the correct value. Keep us posted. Thanks.
Tony
boyt911sc 10-04-2016 08:30 PM
Replacement WUR update.........
Mike
Mike,
Are you getting a replacement WUR or they will worked on the unit you sent back? Keep us posted. Thanks.
Tony
Mike in FL 10-05-2016 02:29 AM
Hi all. Got the replacement wur yesterday and installed it. Absolutely no change in control pressure from cold to warm (54 psi) or resistance (9.9 ohms cold or warm). I'll check the fuel return line tonight (assuming that Matthew stays east of us). Still wondering if I got another bad wur...
boyt911sc 10-05-2016 07:25 AM
Replacement WUR.........
Mike,
Is this replacement WUR a different unit or it was the same one you sent back to them to fix? Give the rebuilder a call and inform them that 9.9 Ohms is not correct. I would not be surprised if they insist that there is nothing wrong with the WUR. This was the same value you had before. A good WUR-090 should read 25~26 Ohms when the engine is cold.
http://forums.pelicanparts.com/uploa...1475675792.jpg
Request for a good working unit. You will have the same problem/s as before and you are wasting valuable time trying to make the 'out of spec. WUR' perform well. You are not alone. BTW, the return line has nothing to do with your problem (electrical resistance). The return line problem would affect fuel pressure and totally unrelated to resistance (Ohms).
Tony
Mike in FL 10-06-2016 04:07 AM
Thanks Tony. I'll keep all posted as to my progress.
Kool-aid-82 10-22-2016 08:08 AM
Repair?
Researching same issue.
Tony, is it posible to repair these WUR ourself?
I also have a WUR-090 our of a 81 SC US Spec. reading 9 ohms.
Original to car and never been touched
http://forums.pelicanparts.com/uploa...1477148512.jpg
http://forums.pelicanparts.com/uploa...1477148840.jpg
I read that it is possible to crack these and make them adjustable, do you recommend that?
boyt911sc 10-22-2016 12:45 PM
Calibration and testing.......
Billy,
Contact the OP about his problem with his WUR-090. He sent the WUR back to the original WUR rebuilder and came back in worse condition. The cold and warm control fuel pressures were way off from spec and resistance reading was 9 Ohms. The rebuilder insisted there was nothing wrong with it. PM 'Mike in FL' for more details.
A good and properly calibrated WUR does not need to be adjusted seasonally. Making it adjustable makes it only convenient to change or alter the cold control pressure but this is a band-aid remedy to compensate for an existing unknown problem.
Rebuilding WUR's is easy and simple. It is the calibration that takes a lot of time and effort specially if you are working on a WUR for an lambda system.
Tony
Mike in FL 10-23-2016 11:04 AM
Latest update. Recently shipped out and just received back my now "calibrated" wur. Put it back in the car. 25.5 ohms resistance when cold with about 27-30 psi fuel pressure. 9-10 ohms resistance and 51 psi fuel pressure. Car starts right up and idles well cold or hot. Do have some minor idling issues but not related to fuel pressure. Bottom line is that the problem was a non-functioning wur. The supplier in Texas supplied me, one at a time, two rebuilt wur's, none of which were calibrated. In fact, when I questioned them, they advised that calibration was not necessary. WRONG! Sooo, if you happen to purchase a wur from any distributor, make sure to ask if it has been calibrated. An expensive lesson, as is a lot of things with these otherwise super cars... Many thanks to Tony for all of his assistance in this matter.
Bob Kontak 10-23-2016 11:22 AM
Tony,
Do you see wide variations in the WUR resistance for the 090? I do seem to remember 8-9 ohms is a common resistance point for 090 WUR's that are not correct.
Any idea what causes the reduction in resistance?
BTW, I have an old beat up 089 that you are welcome to if you wist to add to you collection.
boyt911sc 10-23-2016 03:45 PM
Wur-089........
Originally Posted by Bob Kontak (Post 9330525)
Tony,
Bob,
Interested in your WUR-089. PM sent.
Tony
