OP Parts caliper
I was doing a rebuild on my 86 Carrera brakes and the fronts worked out fine but my rears appear to have a frozen piston on each caliper. With some soaking and a brake shops air pressure we were able to free up one of the calipers but the passenger rear has one stuck piston. I am going to soak it in brake fluid and try again but the mechanic did not think it would work. In my search I have found a source that has a good price (under $100sale list was $400) for each caliper. They are manufactured by OP Parts. The ATE's or remanufactured from PMB are 300/pair. Does anyone have experience with this brand for use as a caliper?
Old 09-27-2016, 02:34 PM
gtc gtc is offline
abides.
gtc's Avatar
If you do a little searching, you can find the new ATEs for $235.
91135242600
Graham
1984 Carrera Targa
Old 09-27-2016, 03:07 PM
Cairo94507's Avatar
For Porsche brakes it is a no-brainer for me, PMB Performance in Sandy, Utah. Eric Shea is the brake guru and I will not trust my brakes to anyone else.
'71 914-6 #0372
'17 Macan GTS
Old 09-28-2016, 06:05 AM
I had this problem with a caliper once. With the caliper off the car I put it in a vice with some packing to get the vice to act on the piston and forced the piston back in. There was an almighty bang and I thought I had broken the caliper in half as I was using a lot of force, but, no, it had pushed the piston back in. Then I cleaned up the bore, refitted it to the car and pumped the piston out with the brake pedal. I was then able to rebuild the caliper. Worth a try.
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 09-28-2016, 07:24 AM
+1 on hooking it back up and pumping it out using the brake pedal. It always works for me.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 09-28-2016, 08:34 AM
