72 rubber bumperette removal
Do I need to remove the bumper to remove the bumperettes? My car has the factory early fiberglass bumper...and those uuggly rubber bumperettes.
Speedo
Old 10-09-2016, 12:26 PM
Yuck...
Old 10-09-2016, 12:29 PM
The bumperettes do have 2 bolts each that go through the bumper. On the back side there will be 2 nuts per side. If you can't get your hand behind the bumper (which I don't think you will) coming up from the bottom, you will have to remove the bumper.
I believe there is 4 bolts in the frunk and another 2 on the sides then the front bumper pulls right off.
Lou
Old 10-09-2016, 12:36 PM
There are four holes with plugs in the front trunk latch bulkhead. Remove those plugs and you can reach the bumperette bolts with a socket extension. No need to remove the bumper or reach underneath.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-09-2016, 01:07 PM
I never knew what those plugs were for. Learned something new...again
Apologize for the bad advice.
Old 10-09-2016, 01:14 PM
Whoo hoo!
Thanks guys! Made my day. My fingers are not 12 inches long and they don't articulate backwards. I was going to have to take the bumper off...
Old 10-09-2016, 01:49 PM
