-   -   Newbie stupid question (http://forums.pelicanparts.com/porsche-911-technical-forum/930861-newbie-stupid-question.html)
914Ravi911 10-02-2016 04:07 PM
New to 911's and have a stupid question. Does anyone know what this switch does?
http://forums.pelicanparts.com/uploa...1475449636.jpg
Techno Duck 10-02-2016 04:16 PM
Switches between the driver and passenger door electric mirror.
boyt911sc 10-02-2016 04:20 PM
Electric side mirrors.........
Have you tried to adjust your side mirrors? Do you know where the adjuster knob is located?
Tony
914Ravi911 10-02-2016 04:31 PM
No I don't know where the adjuster knob is located.
Bob Kontak 10-02-2016 04:41 PM
Drivers side interior door panel upper front. Near the "vent' window.
914Ravi911 10-02-2016 05:04 PM
Here is what I have on the door panel.http://forums.pelicanparts.com/uploa...1475453050.jpg
kinein 10-02-2016 05:20 PM
Do you have a sunroof
Bob Kontak 10-02-2016 05:44 PM
Not the same as my 81. Sorry.
Be patient. :)
phatnine11 10-02-2016 05:47 PM
Ravi,
The switch is usually located about where you windwings are. Also, the top part of the door panel does not have the hole for the directional switch. You should pull the top part of the door panel and see if the wiring is there for the switch.
Cesar
Bob Kontak 10-02-2016 05:49 PM
Originally Posted by phatnine11 (Post 9303204)
Ravi,
Cesar
+1
With a couple of screws you can pull that top panel off and see if the female plug is present.
914Ravi911 10-02-2016 05:56 PM
Ravi,
Cesar
Another weekend project. Thanks for all the responses.
gazzerr 10-02-2016 07:58 PM
On my SC that's the mirror driver/passenger switch.
javadog 10-03-2016 04:36 AM
If this is on your '75, it was not born with electric mirrors, so it would have not had the switch, either.
You might have a switch that was added by a previous owner. Shine a light inside the trunk towards the switch and see what wiring it is attached to and where the wires go.
JR
wayner 10-03-2016 04:50 AM
Any chance your car has twin plug ignition?
On the factory race cars, while the switch was different, that's where the test switches were located for turning off each ignition box
Probably not that but may be ignition related?
What happens when you move the switch?
scotricker 10-03-2016 05:21 AM
It's for the sunroof on my 78 SC
javadog 10-03-2016 05:44 AM
That's not a sunroof switch, nor is it where a sunroof switch should be. A targa won't likely have a sunroof, anyway...
Not likely to be for twin ignition, either. You'd need two switches for that scenario, not one.
The most common "extra" switches added by owners are for oil cooler fans and kill switches.
JR
tdw28210 10-03-2016 09:45 AM
That is the factory sideview mirror L/R adjustment toggle switch. Betting the PO's door top replacement project likely just ignored the mirror adjustment joy stick.
javadog 10-03-2016 10:36 AM
I have to assume he's talking about his '75 targa.
Electric mirrors were introduced in 1976.
Whatever it is for, it was added after it was built, unless he has a '76 that was first sold in a market where the registration date determined the model year that was recognized.
JR
Tony V 10-03-2016 04:34 PM
On my '74 Targa it was added by the PO to manually turn on the fender mounted oil cooler fan.
MBAtarga 10-03-2016 05:17 PM
Could be for aftermarket alarm or fuel pump relay switch for use as theft deterrent - whatever the PO added on the car.
