Fuel door latch
I was putting on my front left fender today and I couldn't get the cable to feed through to the fuel door latch. I know NOW that the wire feeds through a rubber membrane. But for some reason I thought that it was stuck on the back of the latch. When I loosened the bolt that held the latch on, the latch flew apart.
I can't see how to get this thing back together without breaking my fingers. The width of the spring doesn't look wide enough to fit in the holes of the latch. Am I missing something? I can't find it in the Pelican catalog so I assume that they are NLA.
Steve B.
1972 911t
1999 328is
Old 10-03-2016, 12:07 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Steve,
Give our Parts Specialist a call at 888-280-7799 and they may be able to help you with this part.
-Dmitry
Old 10-03-2016, 02:04 PM
FWIW, I managed to get the part back together. There is a cotter pin (that I forgot about) that fits the two large pieces together. The hard part is trying to figure out how the spring goes between the two parts. After about 20 min of trial and error, I got lucky. Quite fiddly....
I am missing the rigid tubing piece, so I will be calling the Parts Specialist.
Steve B.
1972 911t
1999 328is
Old 10-03-2016, 03:25 PM
pors1968's Avatar
I look like your missing the small round rubber or it angle of pict.
Old 10-03-2016, 04:29 PM
Would the rubber piece fit in the top of the part on the right?
Steve B.
1972 911t
1999 328is
Old 10-04-2016, 09:48 AM
pors1968's Avatar
Yes it wont rattle when close
Old 10-04-2016, 02:06 PM
I imagine that part is NLA. My car was recently painted and I suspect that several bits and pieces were "lost." That was probably one of them. I might be able to fashion something that would function similarly.
Steve B.
1972 911t
1999 328is
Old 10-04-2016, 04:00 PM
