-   -   *Help*. Side mirror mounting issue.. 911sc (http://forums.pelicanparts.com/porsche-911-technical-forum/931103-help-side-mirror-mounting-issue-911sc.html)
goldentimerr 10-04-2016 02:17 PM
It took us a day to drill a hole into body and this is how it sits and angle is horrible.
Previous owner told me that this car never came with right side mirror being 77 in Germany. Not sure if that is true .. Is it?
Has anyone experianced with this?
Please help me
I attatched photos as well
http://forums.pelicanparts.com/uploa...1475615807.jpg
http://forums.pelicanparts.com/uploa...1475615860.jpg
ghamilton 10-04-2016 02:29 PM
I'll fire a pic of my 82 with factory flags when I get home.
MARISOL78sc 10-04-2016 02:30 PM
Could be the mirror you are using has a 944 base.
Paul
Pork Chops 10-04-2016 02:44 PM
Having gone through this before it's either the base or, gulp, the holes are in the wrong place. Or both.
pete3799 10-04-2016 02:49 PM
Holes are in the wrong place.
Left and right mounting points are in different locations.
Bob Kontak 10-04-2016 02:50 PM
Paul
No. Wrong position. Positioned it with the hole dimensions of the driver's door.
20 years I have owned this 911 and I just found this out. Easy mistake. Bummer.
My front end is totaled - pay no attention to overlapping panels and the tape :D
http://forums.pelicanparts.com/uploa...1475617726.jpg
http://forums.pelicanparts.com/uploa...1475617842.jpg
MARISOL78sc 10-04-2016 03:04 PM
1978 schttp://forums.pelicanparts.com/uploa...1475618557.jpg
http://forums.pelicanparts.com/uploa...1475618580.jpg
http://forums.pelicanparts.com/uploa...1475618612.jpg
http://forums.pelicanparts.com/uploa...1475618636.jpg
Cook&Dunning 10-04-2016 03:26 PM
http://forums.pelicanparts.com/uploa...1475619943.jpg
Bob Kontak 10-04-2016 03:27 PM
Ouch.
boyt911sc 10-04-2016 03:57 PM
Passenger side side view mirror installation........
For a left hand drive 911, below are the recommended locations of the mounting holes for flag mirror.
http://forums.pelicanparts.com/uploa...1475621764.jpg
http://forums.pelicanparts.com/uploa...1475621795.jpg
Tony
JJ 911SC 10-04-2016 03:57 PM
As said a few times, you put then at the same latitude.
On the driver side you are inches away from the mirror but when you look at the passenger side you are feet away from the mirror so it need to be in a different position to give you the same view.
ghamilton 10-04-2016 04:07 PM
Sorry to confirm what others have said, your mount is in wrong place.
MARISOL78sc 10-04-2016 05:00 PM
I was hoping it was an easy fix (bases wrong)....oops! measure twice and cut once. Why I always consult Pelican on most everything.
