L Jetronic parts missing
My engine does not have the parts inside the oval.
I want to install this part of the system but cannot find
part number 36 (930 207 229 00).
Do you know where I can buy one ( Pelican does not have it, it is discontinued).
Apparently all the other parts are available
To me it looks like a PCV valve.
Do you think I can use any PCV valve ?
Old 10-05-2016, 01:35 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I would not use a PCV valve.
They never seem to be completely air-tight in the reverse direction even from new.
Volkswagen/Audi uses one way valves on their newer cars.
I suggest getting the parts that are available and then find the outside diameter required on the ends and then secure a one way valve.
This should be pretty easy to find. If you can't, I will. I have several resources.
1981 911SC Targa
Old 10-05-2016, 02:50 PM
Bob thanks for your answer.
Would any one way valve work ?
I just bought a check valve for my 16V GTI, that one has the ends for very small diameter hose about 3/16 1/4 inch inside diameter. Would this valve be ok for the 3.2 Porsche engine ?
or do I need to find a valve with a larger inside diameter ?
Old 10-06-2016, 11:37 AM
One more question,
Is this a L Jetronic or it is a Motronic ? I read L Jetronic in the PET Catalog.
The engine is a 1985 3.2 .
Old 10-06-2016, 02:15 PM
DanielDudley's Avatar
One more question,
Depends on what kind of car it is in. It is L Jetronic, but nobody in the Porsche world seems to refer to it as that.
https://en.wikipedia.org/wiki/Jetronic
You understand that Fiat was running this in 124s in 1980, but Porsche did not adopt it until 1984. Using the same name would have been awkward, as Porsche alway wants to appear to be at the vanguard of new technology, which they usually aren't.
Old 10-06-2016, 03:41 PM
TibetanT's Avatar
One more question,
Hello There:
Your 1985 911 3.2L engine uses the same stuff my 1987 944 uses. It is a Motronic system.
Hope this helps.
Good luck.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 10-06-2016, 03:53 PM
Bob,
Is this the part that I should use ?
The ends are 0.525" outside diameter.
Old 10-06-2016, 06:20 PM
