-   -   Rattle noise going over bumps, under front floor board (http://forums.pelicanparts.com/porsche-911-technical-forum/931243-rattle-noise-going-over-bumps-under-front-floor-board.html)
jwakil 10-05-2016 08:33 PM
I've had this annoying rattle in my 81 930 that seems to get louder after driving for some time and when I go on rough roads. Somehow it's not as noticeable when I first start driving. It seems like it is either in the front right suspension, in front of the passenger floor board, or where the AC evaporator is. It's been like this for several years and I want to cure the problem because it's driving me crazy. Its definitely not some small loose thing. It seems like something big and clunky. Anyone else have similar issue?
twistoffat 10-05-2016 09:28 PM
My tip would be the torsion bars. If the bushings have dried up or the grease on the bars they could be knocking.
motofoto 10-05-2016 09:40 PM
In addition to the above, when I bought my car I had a speaker for the alarm system that was loose and just sitting on the cover plate for the steering rack/fuel pump area. It could easily be something rattling around in that area.
tshebib 10-06-2016 05:23 AM
Also, check the outer sleeve/bearing in the steering rack. You need to remove the accordion rubber boot to view. There is a star slip ring that holds the sleeve in and it is known to snap which will allow the sleeve to creep out of place. Don't forget to check the sway bar bushing as well.
ClickClickBoom 10-06-2016 10:38 AM
I had the "rattle" during the process of upgrading the suspension. See my thread, page 3.
http://forums.pelicanparts.com/porsche-911-technical-forum/926798-suspension-upgrade-3.html
wrxnofx 10-06-2016 12:59 PM
Jack the passenger wheel off the ground and take the wheel off. Grasp the lower part of the strut and try and move it left and right. If there is movement in there you would have a loose gland nut that needs to be tightened.
kevin930t 10-06-2016 01:31 PM
I had the same problem and it turned out to be a bad bushing ontop of the strut,you can try using a impact gun to tighten..
Sent from my SM-N910T using Tapatalk
DaveA 10-06-2016 08:47 PM
My friend, Andy Chisholm, told me many years ago that when I heard a strange suspension noise from the front end, it was probably from the sway bar. Twice he was correct. R/Dave
jwakil 10-07-2016 06:23 PM
Well, I checked everything underneath and all the visible joints seem tight. However, I noticed the camber brace in the trunk has a big gap which I don't know if it should be there or not. It is a Renline aftermarket brace. Should the top bolt be all the way down? I didn't jack up the car and try to move it, but I imagine if it was totally lose I wouldn't even be able to drive it. So my question is, is that gap normal?
http://forums.pelicanparts.com/uploa...1475889769.jpg
