Moon Man's Avatar
930 Cranks but will not Start
I broke a key off in the ignition so I replaced the entire key/wheel lock/ ignition assembly. Now the car wont start. It's a '78 with upgraded Elecromotive ignition kit and I don't have a clue where to start... any help would be much appreciated.
Old 10-06-2016, 11:15 PM
T77911S's Avatar
i assume it ran before you worked on it
I would start with what you messed with last before it stopped running.
did you remove any wires?
check to see if any wires came off.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-07-2016, 04:05 AM
Moon Man's Avatar
Yes, it ran fine. I have checked and rechecked several times all the wires and connection in the area that i was working under the dash...
Old 10-07-2016, 10:00 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Does the engine crank but not start (you don't specify this you your first post)? If so, are the fuel pumps running as the engine is cranking? If not, perhaps start with checking to see if their fuse is blown (maybe a wire end touched something when you changed the ignition switch and caused a fuse to pop).
PS - pumps do not run with just the key on - air must be passing over the air metering disc in order for the pumps to run, or the safety switch on the back of the fuel head has to be disconnected (in OEM trim).
Old 10-07-2016, 11:06 AM
(current version of) the thread title confirms that it's cranking -- a no-start condition has one of two issues as its root cause -- no fuel or no spark -- may be easier to start by confirming spark by pulling a plug wire and using a grounded spare (or lawnmower, etc.) spark plug to confirm spark while cranking.
Old 10-07-2016, 11:26 AM
Ha ha - sometimes (shut it, Bob Kontak! ) I'm a slow MF - missed the thread title info!
Good suggestion about spark checking, and the easiest way to confirm if the fuel pumps are operational is to pull the safety switch plug on the back of the air metering housing/fuel head (somewhat difficult to reach), and see if the pumps run with the key in the "on" position.
Old 10-07-2016, 11:49 AM
theiceman's Avatar
hell why not just lift the air plate ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-07-2016, 12:17 PM
On a Turbo, that would be "push down" the air plate as it is a suck through design, and require removing the ridiculous, mail-box air filter housing (if still being used by the OP), which is much more time consuming that pulling the safety switch plug (no fuel squirted into the cylinders that way either, and ****).
Old 10-07-2016, 12:23 PM
