-   -   Another 3.2L question . (http://forums.pelicanparts.com/porsche-911-technical-forum/931451-another-3-2l-question.html)
ppetion 10-07-2016 05:53 PM
Can i be helped connect these vacuums lines ?
Motor is 3.2l
All lines seems to be coming from throttle body and capped by the previous owner . See pictures and as always TIA.
http://forums.pelicanparts.com/uploa...1475887931.jpg
http://forums.pelicanparts.com/uploa...1475887945.jpg
http://forums.pelicanparts.com/uploa...1475887959.jpg
http://forums.pelicanparts.com/uploa...1475887975.jpg
ppetion 10-07-2016 05:55 PM
One more http://forums.pelicanparts.com/uploa...1475888100.jpg
Techno Duck 10-07-2016 06:19 PM
1 - Hose goes to oil tank, near the oil fill tube. Its part of the oil tank breather.
2 - This is the thermovalve for the fuel vapor purge system; one line runs to throttle body, the other goes to the air valve which is located on the right side of the engine bay, also near the oil fill tube
3 - This goes to the same air valve noted above. Its right by the deck lid hinge if i remember right.
4 - Same as above
5 - This goes to the venturi tube for the brake booster
donporfi 10-07-2016 07:03 PM
I think I have the same problem.
http://forums.pelicanparts.com/porsche-911-technical-forum/931190-l-jetronic-parts-missing.html
ppetion 10-07-2016 07:04 PM
Thanks , I appreciate your prompt reply.
Dooodahman 10-07-2016 07:25 PM
Also, save yourself a needless troubleshooting and do a search on "breather hose restrictor" and make sure you have one in the hose that goes to the oil tank near the oil fill tube before you put it all back together.
